Trevak Dal Posted April 16, 2016 Share Posted April 16, 2016 Hey all, I was thinking about disassbling my heldrake and magnetizing it so that I could easily transport it, and was curious if anybody has done that. Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/ Share on other sites More sharing options...
Dagoth Ur Posted April 17, 2016 Share Posted April 17, 2016 Well, not on the same miniature, but super-glue bonds weaken if they are cooled. Pop the drake in your freezer for half an hour-hour and you should be able to gently and carefully break it back up into pieces. Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4367532 Share on other sites More sharing options...
Bloody Legionnaire Posted April 17, 2016 Share Posted April 17, 2016 Super glue doesn't bond the plastic together like plastic glue does. It shouldn't come apart too terribly bad. Try using a brand new blades along the seems to see if that helps? Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4367615 Share on other sites More sharing options...
GalaxyChief Posted April 17, 2016 Share Posted April 17, 2016 I will second the freezer technique. Also maybe try some super glue debonder. Acetone will work as well. Apply it with a brush to exactly where you need it and let it soften the superglue up. Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4368169 Share on other sites More sharing options...
Trevak Dal Posted April 18, 2016 Author Share Posted April 18, 2016 I'll try chucking the turkey in the freezer overnight while I go to work tonight! Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4368373 Share on other sites More sharing options...
Ciler Posted April 18, 2016 Share Posted April 18, 2016 Warn you partner/spouse/parents... Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4369025 Share on other sites More sharing options...
Trevak Dal Posted April 18, 2016 Author Share Posted April 18, 2016 Warn you partner/spouse/parents... Pfft I live on my own and work third shift, and I don't date. Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4369160 Share on other sites More sharing options...
Ciler Posted April 19, 2016 Share Posted April 19, 2016 That's all right then. Did it work ? Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4369621 Share on other sites More sharing options...
Kastor Krieg Posted April 19, 2016 Share Posted April 19, 2016 Also, CA glue debonders and needles, especially on syringes. Turn CA glue into goo. Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4369629 Share on other sites More sharing options...
Trevak Dal Posted April 20, 2016 Author Share Posted April 20, 2016 Yeah I'd let it sit in there an extra day. While I couldn't get the front talons out of that ball socket they glue onto in the torso, I was able to pop the forewings off with a tiny screw driver (the most offending bits for storage) and I think I can seat magnets in the fore arm with a paperclip guide post on each end of it (one on the wing, one on the arm for strength and stability) Link to comment https://bolterandchainsword.com/topic/321524-disassembling-a-super-glued-heldrake/#findComment-4370873 Share on other sites More sharing options...
