Raven Guard Veteran Symbol Corvus Armor
Just a thought the other day....the chapter symbol on Corvus armor is on the right side, not the left.
Should the Raven's head be pointing forward as it is on the left, or should it be pointing backwards, and be the normal RG symbol????
Thanks for any opinions.
The symbol faces its right side.  Placed on the left shoulder, it will face forward.
If FW is the litmus test, then all icons will face to its right side regardless of placement.
Yet, in the real world, for the United States military, if the flag is on the right arm, then the stars are on the right side (or the flag is backward on the right arm).  So, using the real world American military as the model, then the Raven Guard would face forward (or left) if placed on the right arm.
TL;DR - do what you want :happy.:
It usually faces left in frontal depictions - the only exception iirc is the mkVI shoulder pad (that faces right). Dunno why, probably due to mkVI right shoulder pad being supposed to have studs, which leaves the left shoulder for chapter symbol, where it then faces forward?
https://www.forgeworld.co.uk/en-GB/Raven-Guard-MKVI-Shoulder-Pads
faces right.
https://www.forgeworld.co.uk/en-GB/Raven-Guard-MKIV-Shoulder-Pads
​faces left
​Whether other pads or freehands face left or right doesn't matter. GW in their eternal wisdom has shown us THE WAY, and the way... is whatever you like. :) Everybody wins!
Setorax's mkVII shoulder pad has the head facing right too, i just noticed
Edit: I'm with Tibbs on this, on Setorax (similarly as per mkVI) the left shoulder pad is already assigned, so symbol goes on right arm and having the symbol face left means it faces 'forwards' once assembled.
  • 2 years later...
