Hellrender Posted April 18, 2016 Share Posted April 18, 2016 Hey, i'm planning to buy a redeemer for 40k, but i am looking at the option to have it magnetized so it can serve in 30k as a Phobos pattern. When looking at the pics on the GW website, it looks like the inner and outer side of the sponson both hold a single lascannon. That lascannon also looks a lot like the lascannon you get on the Razorback TL lascannon turret. Do you think that if i use 4 spare Razorback lascannons, i can make 2 lascannon sponsons for a Redeemer kit? (Interchanging it with the tank and flamestorm cannon on the Redeemer) Likewise, i would need to convert/magnetize the assault cannon/heavy bolter, but i expect less difficulty with that. Thanks in advance Link to comment https://bolterandchainsword.com/topic/321597-land-raider-sponsons/ Share on other sites More sharing options...
Disruptor_fe404 Posted April 19, 2016 Share Posted April 19, 2016 Razorback lascannons have incomplete power cabling (since it's covered up by the Razorback's chassis). If you're willing to work around that, it probably is fine (the barrels are a tad shorter than proper Land Raider lascannons). Link to comment https://bolterandchainsword.com/topic/321597-land-raider-sponsons/#findComment-4369396 Share on other sites More sharing options...
SickSix Posted April 19, 2016 Share Posted April 19, 2016 Also no need to magnetize the asscan. Just swap out a razorback HB turrett. Link to comment https://bolterandchainsword.com/topic/321597-land-raider-sponsons/#findComment-4369720 Share on other sites More sharing options...
NovemberIX Posted April 19, 2016 Share Posted April 19, 2016 Assuming you need to buy the kits and bits, why not just buy the basic land raider and the redeemer upgrade sprue? It should be cheaper and easier than trying to make something from razorback bits, and the way the lascannons and flamers are mounted is different anyway, so might as well magnetize the whole sponson IMO. Link to comment https://bolterandchainsword.com/topic/321597-land-raider-sponsons/#findComment-4369859 Share on other sites More sharing options...
Hellrender Posted April 19, 2016 Author Share Posted April 19, 2016 Thanks! a friend recommended the exact same thing. Much easier to do that, lol. Link to comment https://bolterandchainsword.com/topic/321597-land-raider-sponsons/#findComment-4369883 Share on other sites More sharing options...
