Magnets for Marine weapons
I always use 2mm, but I magnetise at the wrist. I find &mm doesn't hold strong enough for the model to hold it's pose during gameplay.
Thanks, Ciler. I think I'll have to remeasure to see if I can get away with 2mm without them being seen/me mangling the models. At least with the way they're posed, they'll have the supporting left hand to give stability if I do need to go with 1mm.
  • 2 weeks later...
I use 1mm x 1mm. I put 1 in the 'hand' and then stack 2 I the wrist to get a good strong bond. It's also worth leaving the ones I the wrist a little recessed and the ones in the hand a little 'proud' of the surface so that there is a mechanical 'plug and socket' effect to really tighten the bond up.
