Deathshroud in Cataphractii...
Charlo
Well guys. Would be great if you could write them via fb how cool Cata Deathshroud would be, and that they should stick with the option for both msn-wink.gif
This might cause a chain reaction with other factions wanting to choose, so they would need to introduce it for everyone. I don't think that this is a good idea.
I have no idea why this is a bad thing?
While it would be nice if FW would make all Legion-specific Terminator units have the ability to choose their armour pattern (and they could definitely make sales off alternate models), I doubt they'll do this. I doubly doubt they'll do it for Deathshroud, as I don't see them giving the option to ONE unit and not the others.
Fluff wise it's ok. I'm pretty sure in "The Lion" the Deathshroud were specifically mentioned as wearing cataphractii.
Rules wise I don't see a problem either. No points difference in the armour and both have advantages and disadvanages. As long as your opponent is clear on the rules - why should there be an issue?
Mainly because of established. If there isn't any, then it's fair game ;)
Y'know, I understand why they don't, as it's the cheap solution that requires buying less models, but I wish they would give indominus armour its own rules. Heck, even if it was a token dip in points per model if chosen over cataphractii or Tartaros.
Just when we do get to the siege and scouring and start seeing mk7 and indominus more prevalent etc, it'll be a shame to penalise the fluffy modelling with poor rules.
Screw Indomitus. I want Mk1 Terminator Armour. Although I wouldn't say no to prototype Indomitus set either. (Something like Redwake's armour.)
BOT: I remember when the Deathshroud first came out, there was a large amount of uproar that the models weren't actually in Cataphracti plate. Deathshroud have always been depicted as Cataphracti, it was actually the models that broke the trend.
I'd have absolutely no issue with someone using them as Cataphracti I they were appropriately modelled.
  • 4 months later...
In fairness, RAR, Deathshroud have always been able to choose their armour pattern. However, with the latest rule set, it is absolutely clear that they do as a matter of absolute fact RAR/RAW have the ability to select their armour pattern (assuming they are modelled in it). The FAQ does state that the correct pattern will be stated absolutely in the Unit entry.
Per the FAQ:
"Terminator armour features a powerful support exoskeleton and internal energy supply, but pays for its unparalleled protection with bulk. A model in Terminator armour has the Relentless and Bulky special rules, and is not able to make Sweeping Advance moves unless otherwise specified. They also may not be transported in Rhino APCs. Terminator armour affords a 2+ armour save and a 5+ invulnerable save. Depending on its particular pattern, Terminator armour may also confer additional rules and abilities to its wearer.
If a unit has the option of taking Terminator armour but does not specify a particular pattern, such as the Legion Terminator Squad entry, its pattern is that represented on the physical models used, and only a single type of Terminator armour may be chosen for the unit when included in your army."
And:
"A note on unique and variant Terminator armour: If a unit is described as being equipped with a particular additional variant of Terminator armour, such as the Gorgon Terminators of the Iron Hands, or as wearing a personalised and unique suit, such as the armour worn by the Primarch Horus, the rules for this armour will be provided in the unit’s description and should not be inferred from elsewhere."
The "Favoured of Mortarion" entry:
"In addition to being an HQ choice in their own right, a Deathshroud Terminator unit may be chosen as a bodyguard for any Terminator armour-equipped Praetor of the Death Guard (or the Primarch Mortarion himself). Deathshroud Terminators must always be modelled/painted to be visually distinct from standard Legion Terminator squads to avoid confusion."
Additionally (in case it came up), as has always been the case; [under] Legion Specific Units & Wargear:
"Deathshroud Terminator squads may be chosen as Elites choices for a Death Guard Space Marine Legion force or replace its Command squads."
Hopefully, that clears things up. These are the current rules, and as the Deathshroud entry itself does not specify, and the "Favoured of Mortarion" rule expands, they CAN choose...
Abaddon has by far the coolest Terminator armour rules outside of Primarchs. Rule of cool (and gentlemanly agreement) generally allows Primarchs to Deep Strike where Terminators would gain the rule. As only a minority of Primarchs have actual Terminator Armour...
Most Legion Specifics are Cataphractii, only Phoenix Guard are not, and hypothetically should have an Artificer Armoured option...
I'd really like to see Imperial Fists Huscarl Terminators released, maybe an Indomitus Variant with a 4++, those Storm Shields, maybe as a specific bodyguard unit for Dorn or something...
It'd be cool...
Devourers, Morlocks and Shadow Wardens would be cool too...
The Pyre Guard of Vulkan, are highly unlikely...
http://wh40k.lexicanum.com/wiki/Space_Marine_Honour_Guard_Squad
It'd be cool...
Nope they no longer need one, as you can use phoenix spears on your palatine blades now ;)
It'd be cool...
Nope they no longer need one, as you can use phoenix spears on your palatine blades now msn-wink.gif
Except Palatine Blades don't have artificer armour (apart from the Prefector)... cry.gif
Being able to take an Apothecary helps, but Palatine Blades are still ridiculously squishy compared to Templar Brethren, Suzerains etc. They're devastating on the charge but nearly always melt away in the next turn or two.
  • 4 months later...
