bark stone sealing?
Fellow modelers and basing experts, I have used bark a few times with basing and I'm planning on using it for the rest of my Thunderwolves. I think I need a decently strong clear varnish to seal it and keep it from chipping because every piece of bark I have done so far chips really easily. Do you have any recommendations as far as clear coating goes? I'm thinking acrylic varnish wont be strong enough.. maybe nitrocellulose lacquer? I know that's what they use on guitar finishes and it's pretty tough stuff.
https://bolterandchainsword.com/topic/321899-bark-stone-sealing/
Lacquer is good but if you look at older vintage guitars you will see a lot of chipping and rub off. Urethane is probably the strongest finish.
I would use acrylic enamel over lacquer personally. Enamel seems to be between urethane and laquer as far as durability and a lot easier to find in rattle cans.
