FarFromSam Posted May 2, 2016 Share Posted May 2, 2016 Okay, awkward title, I know, but a while back I watched a how to airbrush video that showed a product that you applied on a painted area that you did not want painted with a different color. Then, after you were finished painting the surrounding area, you could remove the coating quickly and easily with a tooth pick and end up with two separate colors. Now, I figured the hobby shop guy would know what I was talking about when I described it. He didn't. Then I tried to Google it, and found I don't have the words to describe it. So, I come to you all in hope someone can piece together my babble and offer a recommendation. Thanks :cuss Link to comment https://bolterandchainsword.com/topic/322019-temporaryremovable-liquid-paint-coverer/ Share on other sites More sharing options...
Carlson793 Posted May 2, 2016 Share Posted May 2, 2016 I think what you're looking for is called liquid mask. Google is turning up a large number of sites about it/selling it, but I didn't sort through the various applications/uses to find a modeling version. EDIT: Ahh, here's a hobby related forum post about it, looking for the 'best' product. Link to comment https://bolterandchainsword.com/topic/322019-temporaryremovable-liquid-paint-coverer/#findComment-4382556 Share on other sites More sharing options...
Imren Posted May 3, 2016 Share Posted May 3, 2016 Farfromsam: you're looking for this: http://www.amazon.com/Vallejo-Liquid-Model-Color-Paint/dp/B000PHCNMG/ref=sr_1_1?ie=UTF8&qid=1462233786&sr=8-1&keywords=Vallejo+Liquid+Model+Color+Mask+Paint%2C+17ml or this one (same thing) made by Humbrol: http://www.amazon.com/Humbrol-AC5217-Maskol-28ml-Bottle/dp/B006ZY3KZW/ref=sr_1_2?ie=UTF8&qid=1462233919&sr=8-2&keywords=humbrol+maskol I use the Humbrol one and works fine, comes off easy off painted and non-painted surfaces Link to comment https://bolterandchainsword.com/topic/322019-temporaryremovable-liquid-paint-coverer/#findComment-4382585 Share on other sites More sharing options...
Ovidius Incertus Posted May 3, 2016 Share Posted May 3, 2016 I use Vallejo's liquid mask. (You can also find the same product called liquid frisket.) It works just fine, but be careful of scraping your underlying paint when you remove it and know that it can be a real pain in the rear to get out of recesses and details. Link to comment https://bolterandchainsword.com/topic/322019-temporaryremovable-liquid-paint-coverer/#findComment-4382605 Share on other sites More sharing options...
micahwc Posted April 28, 2017 Share Posted April 28, 2017 All of the above are types of liquid latex; you can buy liquid latex by the gallon in costume stores around Halloween. Like seriously, I have a small bottle I bought at Hobby Lobby and for the same price I could get a bottle about 4 times larger at the costume store. It ruins paint brushes pretty good if you don't get the latex out before it dries. I haven't had any problems removing it from a model. It comes off with friction. I'll grab any pieces I can and pull them off slowly, and then I'll rub the area with my finger for a bit to remove most of the rest. Sometimes you have to use something pointy like a tooth pick to remove the last few pieces in a recess. I have some Deadzone terrain that I airbrushed using some of this, and it turned out pretty well. Link to comment https://bolterandchainsword.com/topic/322019-temporaryremovable-liquid-paint-coverer/#findComment-4724605 Share on other sites More sharing options...
Bung Posted June 11, 2017 Share Posted June 11, 2017 I haven't had any problems removing it from a model. It comes off with friction. I'll grab any pieces I can and pull them off slowly, and then I'll rub the area with my finger for a bit to remove most of the rest. Sometimes you have to use something pointy like a tooth pick to remove the last few pieces in a recess. I have some Deadzone terrain that I airbrushed using some of this, and it turned out pretty well. Better use some Blue Tac or something like to remove the Liquid Mask so you wont touch the paint. Another tip is apply it with a sponge like you would do some sponge chipping with color, that will get you some nice irregular scratches. Link to comment https://bolterandchainsword.com/topic/322019-temporaryremovable-liquid-paint-coverer/#findComment-4779249 Share on other sites More sharing options...
