K9ll4 Posted May 6, 2016 Share Posted May 6, 2016 hey is there any air equivalent to naggaroth night because i can't thin paint for airbrush or then my airbrush is clogged or just bad Link to comment https://bolterandchainsword.com/topic/322181-naggaroth-night-equivalent/ Share on other sites More sharing options...
Firedrake Cordova Posted May 8, 2016 Share Posted May 8, 2016 DakkaDakka's compatibility chart lists "Imperial Purple" in the Vallejo Game Colour & Model Colour ranges, and "Deep Amethyst" in the Reaper line (it also gives Amethyst Purple in the Coat D'Arms line, although that's a metallic paint, if I remember correctly). Unfortunately, Imperial Purple doesn't exist in the Game/Model Air lines, so I'm guesssing you'd need to thin any of the above equivalents, which, from what you've said is a problem (I assume you've tried something like Vallejo Airbrush Thinner?). http://www.dakkadakka.com/wiki/en/Paint_Range_Compatibility_Chart Link to comment https://bolterandchainsword.com/topic/322181-naggaroth-night-equivalent/#findComment-4388775 Share on other sites More sharing options...
K9ll4 Posted May 8, 2016 Author Share Posted May 8, 2016 thanks for your answer Link to comment https://bolterandchainsword.com/topic/322181-naggaroth-night-equivalent/#findComment-4388966 Share on other sites More sharing options...
