Thedarkprincesnun Posted May 7, 2016 Share Posted May 7, 2016 Hey guys Does anyone in the uk know of any cheap paint stripping liquid? I've heard of one from tescos but have no idea what it's called Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/ Share on other sites More sharing options...
Brother Dallo Posted May 7, 2016 Share Posted May 7, 2016 I personally use acetone free nail polish remover from SuperDrug. (The blue one) You get a bottle for about £1.50. Be warned, with this stuff, leave the model for a minute or so, then give it a good scrubbing with a toothbrush. I've happily stripped metal, FW resin and plastic. Just don't be a muppet like I was, and leave stuff in it for two weeks. It messed up the detail on a squad of death company. Hope this is useful. Dallo Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4388097 Share on other sites More sharing options...
Thedarkprincesnun Posted May 7, 2016 Author Share Posted May 7, 2016 I personally use acetone free nail polish remover from SuperDrug. (The blue one) You get a bottle for about £1.50. Be warned, with this stuff, leave the model for a minute or so, then give it a good scrubbing with a toothbrush. I've happily stripped metal, FW resin and plastic. Just don't be a muppet like I was, and leave stuff in it for two weeks. It messed up the detail on a squad of death company. Hope this is useful. Dallo Cheers dallo I will have to look into it Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4388105 Share on other sites More sharing options...
Brother Dallo Posted May 7, 2016 Share Posted May 7, 2016 No bother. I reccomend testing it on an old model to get the hang of it. Dallo Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4388145 Share on other sites More sharing options...
Razblood Posted May 8, 2016 Share Posted May 8, 2016 I can confirm that Acetone free polish remover works a treat :tu: You can also use original dettol which wont damage plastic in any way, though it really stinks and you have to be careful to remove all the paint before cleaning with water otherwise you end up with sticky gunk all over your models which is a right pain to remove. Fairy power spray used to be excellent, but from what I understand they've changed the formula so it's useless now :( Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4388329 Share on other sites More sharing options...
CovertToaster Posted May 8, 2016 Share Posted May 8, 2016 I just use cheap multi purpose cleaner in a spray bottle. It's not super strong so takes a little effort but it's completely safe on models. Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4388333 Share on other sites More sharing options...
Razblood Posted May 8, 2016 Share Posted May 8, 2016 Oh and I'd recommend going to wilkos and getting a battery powered toothbrush, saves so much time and effort (tu) Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4388524 Share on other sites More sharing options...
Noserenda Posted May 8, 2016 Share Posted May 8, 2016 Ive used dettol extensively, works like a dream but the smell is a pain, i find popping the models in soapy water for a couple of days (Changing the water every so often) sorts that out though. Its a couple of quid a bottle and can be reused time after time if you strain the floating paint off. Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4388565 Share on other sites More sharing options...
madscuzzy Posted May 10, 2016 Share Posted May 10, 2016 Isopropyl alcohol works well too. :) Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4390561 Share on other sites More sharing options...
duz_ Posted May 10, 2016 Share Posted May 10, 2016 Ive used dettol extensively, works like a dream but the smell is a pain, i find popping the models in soapy water for a couple of days (Changing the water every so often) sorts that out though. Its a couple of quid a bottle and can be reused time after time if you strain the floating paint off. Dettol is the bomb Smell is a pain but goes away after a good undercoat Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4390572 Share on other sites More sharing options...
Arkaniss Posted May 10, 2016 Share Posted May 10, 2016 I'll be attempting to strip some old models tonight using some Dettol so thanks all for the tips! Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4390604 Share on other sites More sharing options...
WarriorFish Posted May 10, 2016 Share Posted May 10, 2016 Oh and I'd recommend going to wilkos and getting a battery powered toothbrush, saves so much time and effort (tu) Ive used dettol extensively, works like a dream but the smell is a pain, i find popping the models in soapy water for a couple of days (Changing the water every so often) sorts that out though. Its a couple of quid a bottle and can be reused time after time if you strain the floating paint off. I think these are both excellent points - a cheap electric toothbrush will save a lot of effort as well as be much better and faster. Reusing you liquid with some straining is also an excellent tip for saving money :) There's a few more tips here. Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4390672 Share on other sites More sharing options...
Kassill Posted May 10, 2016 Share Posted May 10, 2016 Dollar store brake fluid. Just be sure to use gloves and do it in a very very well ventilated place. Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4390812 Share on other sites More sharing options...
Mithrilforge Posted May 12, 2016 Share Posted May 12, 2016 In Australia we have a product called "Simple Green" just a household cleaner that according to "wargamerau" forum members seems to be 100% safe on all your plastic and metal models it says on their website its sold in over a 100 countries , it may be on your local shelf... Mithril p.s. i have used it too, left the models soaking for about 2 days then stripped them easily with an old toothbrush , you can even reuse the product if you filter it back into the bottle via a coffee filter etc Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4392010 Share on other sites More sharing options...
DistroyA Posted May 12, 2016 Share Posted May 12, 2016 I've had good experience with dettol in the past, although I've recently moved onto using pure isopropyl alcohol (or isopropanol as it's usually branded), as that's the ingredient in dettol that does the magic, and using it undiluted means a faster stripping time. It's kind to plastic for definite (unsure about resins though). I bought a litre bottle off ebay for under £7, so if that sounds appealing, I'd recommend that over any other chemical, particularly any form of nail polish remover as I've had somewhat negative results from using even acetone free polish remover. At the end of the day, it's down to one's own personal preference. :) Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4392066 Share on other sites More sharing options...
Brother Desultor Posted May 12, 2016 Share Posted May 12, 2016 I too am using IPA having tried many other options. I get mine from Amazon for £7.99. https://www.amazon.co.uk/gp/product/B00WL8NHEA/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1. One word of advice when using it with resin models, if you leave them to soak for a few days it will soften the resin. And although it will harden again over time, it will never attain the original rigidity. Well, at least from my experiences so far. Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4392161 Share on other sites More sharing options...
DistroyA Posted May 12, 2016 Share Posted May 12, 2016 Ah, but you don't need to leave them to soak that long. 15 minutes is the minimum time required. Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4392430 Share on other sites More sharing options...
Brother Desultor Posted May 12, 2016 Share Posted May 12, 2016 That is extremely useful to know - thank you. Link to comment https://bolterandchainsword.com/topic/322203-cheap-paint-stripping-liquid/#findComment-4392452 Share on other sites More sharing options...
