GreyCrow Posted May 11, 2016 Share Posted May 11, 2016 Hello guys ! Any tips to make the decals stick ? I order a set of Raven Guard decals from Forgeworld and the slightest touch gets them off. Link to comment https://bolterandchainsword.com/topic/322320-decals-not-sticking/ Share on other sites More sharing options...
JeffTibbetts Posted May 11, 2016 Share Posted May 11, 2016 Is it possible you're letting them soak in water too long? You should apply them the moment they become loose. Also, can you tell us a bit about your process? Are you using any chemicals or just water, straight on a painted surface? Link to comment https://bolterandchainsword.com/topic/322320-decals-not-sticking/#findComment-4391865 Share on other sites More sharing options...
Bloody Legionnaire Posted May 11, 2016 Share Posted May 11, 2016 I like to put some 'ardcoat on mine after it dries just to protect the decal a little bit, but I really don't have a problem with the decals sticking when they dry. Do you put a little bit of 'ardcoat or gloss varnish the model before you apply the decals? Link to comment https://bolterandchainsword.com/topic/322320-decals-not-sticking/#findComment-4391878 Share on other sites More sharing options...
GreyCrow Posted May 11, 2016 Author Share Posted May 11, 2016 Hey ! It's possible that I wait too long to soak, but they don't come off on their own, so maybe I didn't soak them long enough. And it's indeed straight on paint, but I will look at 'ard coating the surface before and after. God that cross dealing scheme ! Link to comment https://bolterandchainsword.com/topic/322320-decals-not-sticking/#findComment-4391946 Share on other sites More sharing options...
Bloody Legionnaire Posted May 11, 2016 Share Posted May 11, 2016 GW transfer decals are not of the greatest quality... they are pretty stiff an don't form well especially to rounded surfaces. Many modelers find it necessary to make very tiny cuts in the decals to help them lay over rounded surfaces like pauldrons. You could try picking up some of testors decal solution for complex surfaces. There's actually quite a few model products on the market that help decals set on surfaces. A quick google search will bring up all the info you'd want/need. Link to comment https://bolterandchainsword.com/topic/322320-decals-not-sticking/#findComment-4391954 Share on other sites More sharing options...
krakenfiend Posted May 11, 2016 Share Posted May 11, 2016 Best bet is Microscale Industries Micro Set and Micro Sol. krakenfiend Link to comment https://bolterandchainsword.com/topic/322320-decals-not-sticking/#findComment-4391958 Share on other sites More sharing options...
Carlson793 Posted May 11, 2016 Share Posted May 11, 2016 See my sig for Winterdyne's decal tutorial. Covers all you need to know for placing transfers, whether home made or GW/FW. Link to comment https://bolterandchainsword.com/topic/322320-decals-not-sticking/#findComment-4391975 Share on other sites More sharing options...
Guiltysparc Posted May 12, 2016 Share Posted May 12, 2016 Yep, get th3 microscale system. I use it on my dudes and then I out a coat of testor's dulcote via brush over it to knock the gloss of the decal down. Link to comment https://bolterandchainsword.com/topic/322320-decals-not-sticking/#findComment-4392063 Share on other sites More sharing options...
