ETL help
Atrophus
So I'm looking to pledge a praetor and a terror squad for ETL.
The only problem is I've modelled my praetor with a single lightning claw and power fist, but I'm not sure of the points cost/if it's a legal set up?
I modelled him that way just for the way he looks.
Would I just pay the points for a set of lightning claws then swap one for a power fist?
Thanks in advance :)
https://bolterandchainsword.com/topic/322444-etl-help/
In TDA (cataphractii or otherwise) this is unfortunately not allowed. The combi-bolter can only be exchanged for other ranged weapons.
Whaaaat, I can give my Devoured twin-chainfists and swap out my combi-bolter for a shield though? Or twin-lightning claws?
Can you source please?
https://bolterandchainsword.com/topic/322444-etl-help/#findComment-4396151
Praetor's options becomes severely limited when you purchase terminator armour. It changes from the "may replace bolt pistol and/or chainsword for one of the following from the same list of options" wording to "may exchange combi-bolter for an option from a specific list" and "may exchange power weapon for an option from a specific list". So no mixing and matching weapons when in termie armour.
https://bolterandchainsword.com/topic/322444-etl-help/#findComment-4396185
LACAL p. 14. It's what Runefyre wrote. The weapon choices under the Options heading become unavailable because the praetor in TDA no longer has a bolt pistol, chainsword or combat blade to give away. Other options that do not replace anything (e.g. melta bombs) are still available after he has taken TDA.
https://bolterandchainsword.com/topic/322444-etl-help/#findComment-4396211
