NiceGuyAdi Posted May 16, 2016 Share Posted May 16, 2016 I've made up a base for my Scout Sergeant. I had always meant to add barbed wire to it, but forgot about in until I'd primed it and added some Agrellan Earth to vary the texture in the sand. I really don't want to re-prime the base, so am wondering what might work instead. I've got some Lahmian Medium, 'Ardcoat, or could just try basing it with Abaddon Black. Any one out there know what would work best? Link to comment https://bolterandchainsword.com/topic/322470-undercoating-without-primer/ Share on other sites More sharing options...
sockwithaticket Posted May 17, 2016 Share Posted May 17, 2016 Brush on primer, vallejo have an extensive range. Others probably do, too. Just don't get the GW stuff. I've never seen anyone say anything good about it. Link to comment https://bolterandchainsword.com/topic/322470-undercoating-without-primer/#findComment-4396846 Share on other sites More sharing options...
Carlson793 Posted May 17, 2016 Share Posted May 17, 2016 ...or, if you use rattle can primer, get a disposable cup and spray a significant amount into that to get brushable primer. Link to comment https://bolterandchainsword.com/topic/322470-undercoating-without-primer/#findComment-4396885 Share on other sites More sharing options...
NiceGuyAdi Posted May 17, 2016 Author Share Posted May 17, 2016 ...or, if you use rattle can primer, get a disposable cup and spray a significant amount into that to get brushable primer. Genius! Link to comment https://bolterandchainsword.com/topic/322470-undercoating-without-primer/#findComment-4397167 Share on other sites More sharing options...
Carlson793 Posted May 17, 2016 Share Posted May 17, 2016 ...or, if you use rattle can primer, get a disposable cup and spray a significant amount into that to get brushable primer. Genius! Mother of Invention... We don't get many low humidity days around here, and I've got too many models to get primered on the few we do get. Mind, you'll likely get some primer on your fingers, but you're used to that already, right? Link to comment https://bolterandchainsword.com/topic/322470-undercoating-without-primer/#findComment-4397327 Share on other sites More sharing options...
