Dark Angels "Ironwing Protocol" 2500 points
Given the quietness of the Army List Forum, I thought I'd throw this out there for a bit of critique. :)
Space Marine Legions
HQ
Delegatus: Rite of War (Ironwing Protocol); artificer armour; volkite serpenta; Terranic greatsword; boarding shield 105
Damocles Command Rhino
TROOPS
10 Tactical Space Marines: Tactical Sergeant (artificer armour; melta bombs); 9 Tactical Space Marines; nuncio-vox; legion vexilla 185
Rhino: dozer blade 40
ELITES
9 Veteran Space Marines: Veteran Sergeant (artificer armour; volkite serpenta; Calibanite war blade); Fearless; 8 Veteran Space Marines; 8 × volkite serpenta; nuncio-vox; melta bombs 285
Contemptor Mortis Dreadnought: 2 Kheres pattern assault cannons 180
HEAVY SUPPORT
Artillery Tank Squadron
Medusa
Medusa
Vindicator Siege Tank Squadron
Vindicator: laser destroyer array 130
Vindicator: laser destroyer array; machine spirit 155
Legion Predator Strike Squadron
Predator: heavy bolter sponsons; dozer blade; heavy bolter 115
2,500 points
Tactics:
- Delegatus joins the Fearless Veterans for a 3rd scoring unit, plus the Exterminators bonus on volkite serpentas.
- Damocles is pretty much there to unload it's Orbital Strike and manipulate Reserves (not that I have anything I need to).
- 3 las Vindicators for anti-tank, with Machine Spirit to split fire.
- 2 Dakka Preds to unload 26 BS5 shots into infantry/bikes/light vehicles.
- Medusae do what they do best - murderate.
- Kheres Mortis Dreads are the real gems though - 12 BS5 S6 Rending shots each, with Tank Hunters. :)
- I would recommend you do the math on 3 Mortis and 3 Mortis-type Cortus to see what the difference in production is.
  - Taking a talon, would let actually make your list legal without the Damocles and give you some more non-tank choices as currently you have 7 tank units and 7 non-tank units
- I would drop dozer blades, on your tanks, since you ignore the first failed test anyway
- I would still put a vexilla on the vets so you can change their trait if you need to
- alternatively you could keep the Damocles and instead add a Dreadclaw which would let you DS the vets or better yet you could do a Terminator squad in a dreadclaw with chargers, and a small bike squad for the delegatus to join.
