Blackarmor_redtruth Posted May 29, 2016 Share Posted May 29, 2016 While I have a few small options of where to play, the biggest is at a place that has a LOT of folks who use it as a testing ground for regional tournies. I know the game is pretty fluid and you have to read what missions and set up you get and then what your opponent even brings, but it's been a more than a few months since I've played. One list that will be there this upcoming month is: http://thetyranidhive.proboards.com/thread/51159/1850-list-portland-june-swolves I know a strong shooting ork with dakkajets and necron decurion detachments are there, with at least three bike armies (DA, White Scars, ... other I haven't played vs), and the above Space Wolves. My usual list is along the lines of St Celestine with six hand flamer seraphin, two melta doms with bombs and immo (MM), two exorcist, IK paladin, canoness either with heavy bolter celestians or on quad-gun duty (normally this) behind Aegis line. My SoB are usually flame, melta, and 8-10 strong with one minimum squad with flamer as chaft. My concerns and questions for my fellow Faithful: should I stick to the mission and just try to tie-up units best i can, because my meta is crazy hard hitting and mobile. Everything has mobility it seems. Or go for my normal pincher attack of softening targets with exorcists/IK, then pinch with IK + (1 or 2) Dom squads? I think I'm mostly just nervous as well. The Emperor Protects! Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/ Share on other sites More sharing options...
Naminé Posted May 29, 2016 Share Posted May 29, 2016 Rule number one of victory in 40k: make a battle plan and stick to it, no matter what. Never second guess yourself as you play, and you'll end up winning more often than not. Competitive play is the same thing. Most heavy hitting lists are run by people who are actually quite lacking tactically, or have no confidence in their ability to play beyond following the herd-mentality of the meta. These are the types of players you will always beat if you stick to your plan. A small number of players will be using a WAAC list, and have a tremendous amount of skill. Yet again, stick to a plan and if you don't win, you'll still freak them out for the next time you play :p Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4407299 Share on other sites More sharing options...
BitsHammer Posted May 29, 2016 Share Posted May 29, 2016 I brought a general TAC list and played the missions as best I could. And mocked Marine armies who were supposibly "unbeatable" when I pounded them flat. Good fun. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4407426 Share on other sites More sharing options...
Servant of Dante Posted May 29, 2016 Share Posted May 29, 2016 I brought a general TAC list and played the missions as best I could. And mocked Marine armies who were supposibly "unbeatable" when I pounded them flat. Good fun. The only thing in this galaxy that is unbeatable is our faith in the Emperor! Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4407464 Share on other sites More sharing options...
ValourousHeart Posted May 29, 2016 Share Posted May 29, 2016 My usual list is along the lines of St Celestine with six hand flamer seraphin Sorry just read this and thought but we can only get 2 seraphin with hand flamers per squad. Did I miss a change? Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4407485 Share on other sites More sharing options...
Servant of Dante Posted May 29, 2016 Share Posted May 29, 2016 My usual list is along the lines of St Celestine with six hand flamer seraphinSorry just read this and thought but we can only get 2 seraphin with hand flamers per squad. Did I miss a change? You are right, it's 2 per squad. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4407547 Share on other sites More sharing options...
Aqui Posted May 29, 2016 Share Posted May 29, 2016 Unless Blackarmor_redtruth was using three squads of Seraphim, which seems a little excessive (I love Seraphim, but the points are better used elsewhere) Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4407558 Share on other sites More sharing options...
Rasp Posted May 30, 2016 Share Posted May 30, 2016 I think he meant a squad of six seraphim (2 of which have hand flamers). My advice is stick to the mission. We don't always have the tools to trounce the new flavor of the week. But we are almost never completely out of the fight. If you try to play their game you will come up short. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4407912 Share on other sites More sharing options...
Frater Cornelius Posted May 30, 2016 Share Posted May 30, 2016 People tend to use easy lists that yield the most results. That is the only way I can explain weird-looking lists placing well. You need to have a good idea what to expect and how to counter. The rest is up to the dice and out of your hand. Stick to your plan and you win ;) Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4408236 Share on other sites More sharing options...
ElectricPaladin Posted May 30, 2016 Share Posted May 30, 2016 I stay away from them. They're no fun. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4408256 Share on other sites More sharing options...
Blackarmor_redtruth Posted May 31, 2016 Author Share Posted May 31, 2016 Thank you all for the comments, let me clear some things up. A squad of six seraphim with hand flamers - just the normal two sets. I may have assumed a short hand and caused some confusion, apologies. For tactics, I'm pretty straight forward and KISS, IK threatens as it moves up to Stomp/RCS, exorcist pound from max range, StC and seraphim harass blobs or tie-up units, SoB take objectives and threaten anything within range, doms come in and nuke then advance if needed or bunker on backfield objectives. My weakness I guess is a bit two-tied/two-fold. I know the threatening lists and generally what they do, but I don't play enough to be familiar with important things like say certain Chapter Doctrines. I know just enough to be afraid and that cripples me - Emperor Protects. Edit: why do my texts, written with spaces and paragraphs, always appear as one giant block? Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4408549 Share on other sites More sharing options...
Spacefrisian Posted June 1, 2016 Share Posted June 1, 2016 Rule number one of victory in 40k: make a battle plan and stick to it, no matter what. Never second guess yourself as you play, and you'll end up winning more often than not. Lol i disagree, i do like Sun Tzu once wrote, work out victory according to how the battle goes, iam like water...but in case of battle sisters that would be more like fire. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4409358 Share on other sites More sharing options...
*Furyou Miko Posted June 1, 2016 Share Posted June 1, 2016 Prometheum is the best of both worlds - it's a fluid, like water, but it burns like fire. <3 Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4409455 Share on other sites More sharing options...
ValourousHeart Posted June 1, 2016 Share Posted June 1, 2016 Rule number one of victory in 40k: make a battle plan and stick to it, no matter what. Never second guess yourself as you play, and you'll end up winning more often than not. Lol i disagree, i do like Sun Tzu once wrote, work out victory according to how the battle goes, iam like water...but in case of battle sisters that would be more like fire. Sun Tsu also talked about how a war was won before the armies went to battle, and about how indecision was a greater enemy than your opponent. So in essence you are both following his advice. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4409619 Share on other sites More sharing options...
Drider Posted June 1, 2016 Share Posted June 1, 2016 Sun Tsu also talked about how a war was won before the armies went to battle Yup, 40k is about 75% list building. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4409621 Share on other sites More sharing options...
BitsHammer Posted June 1, 2016 Share Posted June 1, 2016 Sun Tsu also talked about how a war was won before the armies went to battle Yup, 40k is about 75% list building. I disagree. Yes, having a well balanced list is good, but even the stompiest list won't win you games if you use it poorly. I'd say it's only really a third of the game. 1/3 list building, 1/3 Modelling/painting, 1/3 tactics once the army is deployed and everything goes sideways. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4409637 Share on other sites More sharing options...
Drider Posted June 1, 2016 Share Posted June 1, 2016 I mean just from a playing the game on the table perspective rather than a hobby perspective. So disregarding the 1/3 painting/modeling you're left with 50/50 list building/game play. I'd argue that someone with a good list and average game play would do better than someone with an average list and good game play. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4409652 Share on other sites More sharing options...
BitsHammer Posted June 1, 2016 Share Posted June 1, 2016 Funny because I would table good lists and average game play. Yes a good list is important but being too confident only in your list and not in various strategies to use that list is how you lose. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4409865 Share on other sites More sharing options...
Naminé Posted June 1, 2016 Share Posted June 1, 2016 Yes, I feel that the ratio between player skill and lists is actually very difficult to define and flexible, resulting in disagreements such as these. The truth is, we can only look to both strengthen our lists and develop our skills if we want to win. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4409961 Share on other sites More sharing options...
Servant of Dante Posted June 2, 2016 Share Posted June 2, 2016 Yes, I feel that the ratio between player skill and lists is actually very difficult to define and flexible, resulting in disagreements such as these. The truth is, we can only look to both strengthen our lists and develop our skills if we want to win. Honestly, the game isn't about winning to me. Most of my favorite games where close ones that I lost. To me, an engaging experience and cool action is far and away more important that winning or losing. That being said, I don't enjoy being on either side of a blow-out/curb-stomp. Ex. Granted, this was a game of 3E, but I was using my BA against my friend's chaos (he was playing Tzeentch, using the 3.5 codex. I love that book.) He started in the middle and had to get to the edge of the table with I think half of his units. In the end it came down to a group of termis in difficult terrain on the last turn of the game. They where 4" from the table edge. They made it, just barely. As a side note, you don't get armour against dangerous terrain in 3E, and it's not just a wound, it flat out kills the model. My Sanguinary High Priest (something like 180pts) jumps out of terrain using his jump pack to confront the termis, and rolls a 1. It was hilarious! I had to check the rules, but yeah, he had 2 wounds, and he was dead! Now I have this image of a 800 year old SM Captian (probably a Ultra Marine) riding his bike through the forest. He hits a bump or a log, and flies off into a tree, killing him in a ball of fire like on Endor in Star Wars. That's ridiculous and fun. And with the AoFs you can get a squad an invuln equal to their armour, so cloak of St. Aspira and that AoF for 2++! Well, I didn't expect to write so much. I apologize for going off topic. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4410443 Share on other sites More sharing options...
Drider Posted June 2, 2016 Share Posted June 2, 2016 Honestly, the game isn't about winning to me. Most of my favorite games where close ones that I lost. To me, an engaging experience and cool action is far and away more important that winning or losing. That being said, I don't enjoy being on either side of a blow-out/curb-stomp. THIS! My two favorite games have been ones that were drawn almost the entirety of the game, both of which came down to turn 7 before one person managed to pull out the win at the last moment to win by one point. I lost both of these games but they are undoubtedly my favorites. Last night I was absolutely destroying a guy at my club who was playing Corsairs. He was just getting really unlucky with his shooting and save rolls. In a 1750 game by the end of turn 3 he only had 3 units left alive, 2 of which only had 2 models left, so we just desided to call it at that because neither of us were enjoying the game and couldn't be bothered playing it out to the inevitable turn 4 tabling. This is an example of the luck he was having, his Wraithknight with double wraith cannon totally wiffed it's T1 shooting phase, got taken down to 1 HP by 12 melta, 3 multimelta and 3 exorcists. The next turn it takes out an Exorcist, takes a lone penitent engine to 1hp and charges it only to die to a heavy flamer in overwatch. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4410453 Share on other sites More sharing options...
BitsHammer Posted June 2, 2016 Share Posted June 2, 2016 Close games are the best games. Granted pulling out an impossible win (4 models left on the table vs mostly intact Necron Decurion for a personal example) feels nice but not as much as a game where you feel like both of you could have won and it feels properly narrative. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4410504 Share on other sites More sharing options...
ValourousHeart Posted June 2, 2016 Share Posted June 2, 2016 I agree, the best games in my opinion are the ones that have a spectacular comeback or something funny kept happening that made the crowd around the table roll with laughter. One game I had back in 4th I lost half of my models on the top of turn 1... I couldn't make a save. And lost the last 2 scoring models in turn 3. By the end of the game I only had 2 land speeders, but had managed to cause all of his scoring units to be wiped out or falling back. From certain defeat to a draw. The funny game was Drop IG vs Ravenwing. The terrain was set up with a huge piece in the center and a couple of small pieces in the corners. It kinda looked like a motorcross track... So that is how I played the game, I could only make left turns and no one could go back up the track. After a couple of turns, everyone was rooting for which bike they thought was going to win the race, and the IG were just dirty tricks to sabotage the guys at the head of the pack. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4410554 Share on other sites More sharing options...
BitsHammer Posted June 2, 2016 Share Posted June 2, 2016 Celestine not coming back to the table began with get a reputation as "tea time with the Emperor". Which she seemed to do 80% of the time. Surprisingly a 50% of getting her back seems far less in my hands. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4410569 Share on other sites More sharing options...
*Furyou Miko Posted June 6, 2016 Share Posted June 6, 2016 http://img.photobucket.com/albums/v205/KaguraHakubi/Forum%20Comments/MikoGlasses_zps6c33be16.png No plan survives contact with the enemy. http://img.photobucket.com/albums/v205/KaguraHakubi/Forum%20Comments/MikoUnimpressed-1.png That's fine. We don't have plans. http://img.photobucket.com/albums/v205/KaguraHakubi/Forum%20Comments/MikoSatisfied.png We just have melta guns. http://img.photobucket.com/albums/v205/KaguraHakubi/Forum%20Comments/Miko%20darkglasses_zps7rtgljan.png Melta guns are much better at surviving contact with the enemy. Link to comment https://bolterandchainsword.com/topic/322822-how-do-you-handle-waac-tournaments/#findComment-4413268 Share on other sites More sharing options...
