Marshal Rohr Posted May 29, 2016 Share Posted May 29, 2016 Since most of the material is no longer available does anyone know what the comparable TOEs of epic scale units are compared to their 40k counter parts? For instance is 2 stands of infantry and a chimera meant to represent an abstraction of a Steel Legion platoon or a truer 1:1 squad parity. Link to comment https://bolterandchainsword.com/topic/322830-unit-size-in-epic/ Share on other sites More sharing options...
Kalrath Posted May 29, 2016 Share Posted May 29, 2016 It's +- 1:1 1 Chimera and 2 stands represents a squad (5 models each stand) I say +- because, in Epic Armageddon rules, base sizes aren't fixed, and the number of models per stand (according to the rules) may varie: • A stand may be no more than 40mm and no less than 5mm across in any direction. • A stand must be at least 20mm across in one direction (i.e., a 5mm by 5mm stand is not allowed, but a 5mm by 20mm stand would be okay). • Stands representing infantry units must have at least three infantry models and may not have more than seven. Infantry mounted on bikes or horses must have between two and four models mounted on each base. • Stands representing artillery must have between one and two artillery pieces and up to six crew models. However, you don't use squads in Epic, you use platoon sized formations (12 stands and 6 chimeras). With other rules (Epic Space Marine/Titan Legions or Epic 40k) the bases are fixed and relationship of models per base is also 1:1. i.e. 5 models in a base represents 5 actual individuals, so a squad of Space marines would be 2 stands. Here is the link for the current rules (revised regularly): http://www.net-armageddon.org/ And the forum with a currently very active community: http://www.tacticalwargames.net/taccmd/index.php Hope this helps. Link to comment https://bolterandchainsword.com/topic/322830-unit-size-in-epic/#findComment-4407621 Share on other sites More sharing options...
Marshal Rohr Posted May 29, 2016 Author Share Posted May 29, 2016 You're the man, brother. Just what I was looking for. Edit: That Death Korps list is awesome Link to comment https://bolterandchainsword.com/topic/322830-unit-size-in-epic/#findComment-4407721 Share on other sites More sharing options...
Kalrath Posted May 29, 2016 Share Posted May 29, 2016 Cheers! Njoy! Link to comment https://bolterandchainsword.com/topic/322830-unit-size-in-epic/#findComment-4407751 Share on other sites More sharing options...
Mard Posted June 9, 2016 Share Posted June 9, 2016 I will just jump in and say that the http://www.net-armageddon.org/ is completely out of date and do not use the army compendium Here is the current website for all fully approved army lists and the current rulebook and FAQ's - http://www.tp.net-armageddon.org/ Armyforge is a good quick army list builder (Not always up to date with lists but pretty good - https://traitor-legion.appspot.com/indexNETEA.htmlAnd Taccoms is still the most active community website and where the other current lists are still in development or experimental stages - http://www.tacticalwargames.net/taccmd/index.php Link to comment https://bolterandchainsword.com/topic/322830-unit-size-in-epic/#findComment-4415280 Share on other sites More sharing options...
