Cataphractii Primus Medicae?
Then see if you can grab some AM (sorry, guard) missle teams. The missle packs make great meedles and cylinders.
The important quesion brother Alpah legionaire is why you arent using deathshroud....
Also throw on a void shield harness if you can afford it and your meta is cool with it. Really :cusss with people.
Deathwing bits worked fine for me. Mind you, my greenstuff skill at the time was...well, wasn't, but it still turned out okay. Firedrake base, but still Cataphractii.
med_gallery_80588_10505_72296.jpgmed_gallery_80588_10505_136861.jpgmed_gallery_80588_10505_12116.jpg
How did you attach the narthecium?
This is mine using the grey knights parts and a holstered pistol for the needle pistol.
http://i263.photobucket.com/albums/ii160/gordonayr/Mobile%20Uploads/IMG_20160421_213744_zpsosj9zdvk.jpg
How did you get the tassles on the narthecium arm?
I'm making my Iron Warriors one out of the Iron Hands Cataphracti Iron Father, cut the Grey Knight narthecium arm off at the elbow and putting it on the remain arm, then adding the additional grey knight apothecary bits like the vials and the little lamp on top.
I....I painted the shoulder pads white.
I am not a creative person.
So he takes progenoid glands out with his bare hands, like a man!
I saw someone drill a hole in part of a chain fist, then snap the end of the drill off and glue it into the hole. Works quite nicely. You could use the promethium tanks off of a flamer too to show where the...juicy bits are stored. ;)
If the Praetor's model is anything like normal Cataphractii armour then there is no way you will get a full helm into the gap.
Personally my Primus Medicae's armour is Tartaros but I'll just play it as 'counts as cataphractii', and the Tartaros was much more willing to accept a helmet without adjustments
A normal sized head WILL fit into the Praetor torso. It will also fit into Tartaros torsos, which are fully compatible with Cataphractii arms and legs. You could make the armour look specially artificed.
By head do you mean a helmet? Like the IW helmets from fw?
Yup. Heads and helms.
Great, the praetor as he is atm looks a little to fancy for an Iron Warrior, hope I can cut out the current head without many problems, wish I hadn't put it together before I decided to change it. Was the head by itself in the plastic model or part of the whole frame?
