Putting glow in the dark paint in an airbrush
Here is from the Revell Service Alerts:
GLOW IN THE DARK PAINT
Due to difficulty of application, Revell Germany NIGHT COLOR Glow in the Dark acrylic paint is not suitable for children under 8 years of age. It is recommended for use by experienced builders.
Night Color paint is purposely formulated with a very thick consistency. Prior to use, dilute with a very small amount of water and gently stir.
Night Color paint can be applied with a regular brush and quickly dries to a permanent finish. Apply generously to model and let dry. If desired, a second coat may be applied.
Blotchy appearance is normal, and necessary, in order to achieve Glow in the Dark effect. To ensure permanence, allow to dry at least 3 days.
Use ordinary soap and water to clean brushes and any spills that may occur.
Night Color Glow in the Dark acrylic paint casts a greenish glow which is easily recharged with light.
Without seeing that paint i think it will be hard to airbrush due to some big pigments and you may need more than one layer.
But i havent seen some good reviews about that paint maybe look for another manufacturer.
