Enginseer w/ four servitors - 1+ repair?
I'm watching a video going over the Space Marine FAQ.  There was an item in that FAQ for Blessings of the Omnissiah.
The FAQ says that this can go off on a 1+ if the unit has four servitors.
The Enginseer unit with four servitors costs 80pts.  120pts if you give the servitors multi-meltas.
Pask and the multi-melta servitors have a 24 inch range, that goes well together.  Park this unit behind Pask and keep them out of line of sight.
Anyone ran anything like this?
I was about to say its probably not worth it, as he can only fix weapon destroyed/immobilised results and put hull points back BUT then I remember that tech priests can also hand out POTMS, effectively negating everything except an explodes on the damage chart!
I've been considering an allied ig detatchment to get some imperial priests into my black templars...
So I was fiddling with battle scribe...
Company comand with astropath, master of ordinance, officer of the fleet. Cammo, medic, vox, 2xsnipers.
Veteran squad, mortar, 3xsnipers, forward sentries.
3xministorum priests
3xenginseers with 5 servo-tors each, a Trojan support vehicle with heavy stubbed each.
All comes to 748pts.
Lots of tools and things. Each enginseer team can support different armour on different ends of the table.
The vets and ccs hide, and if they can smack a few things with that artillery support and manipulate a few reserve rolls then good.
This is the whole shebang imo, so trim to taste. (If you aren't playing black templars add slotless psychers to)
isn't the result of 1 always fail?
and yes. i saw stormlord with 3 priests and 4 servitors on a landing pad with 20 jokaeros shooting outside of it. sweet times of battlebrothers' transports.
Not for repair rolls because the harnesses/servitors add +1 to your roll.
​It's in the FAQ too :)
Yea the pass on roll of 1 is strange, but that is what they put in the FAQ...
