Chesco Posted June 22, 2016 Share Posted June 22, 2016 Has nayone had any luck with magnetizing these combi weapons? I would like to attach the gun to a Sgt. and be able to swap combi-bits as needed. So far i have had no lluck getting smallthin enough magnets. I have searched the site and Google, but have had no luck so far. Thanks for any suggestions. Link to comment https://bolterandchainsword.com/topic/323384-putting-magnets-in-the-bc-combi-weapons/ Share on other sites More sharing options...
Major_Gilbear Posted June 22, 2016 Share Posted June 22, 2016 The only part that's different between all three combos is the nozzles: http://i.ebayimg.com/00/s/NzQwWDgyNw==/z/pH8AAOSwvt1WR5tb/$_35.JPG So why not cut all three nozzles off and magnetize those? It'd let you assemble the main part of the gun solidly that way, and relieve any issues you may have with the Sergeant holding the weapon two-handed. Small 1mm x 1mm magnets likes these should do the trick! Link to comment https://bolterandchainsword.com/topic/323384-putting-magnets-in-the-bc-combi-weapons/#findComment-4425899 Share on other sites More sharing options...
Ovidius Incertus Posted June 22, 2016 Share Posted June 22, 2016 Haven't tried them with the BaC combi-weapons, but on similar style, side-mounting FW combis, a 1/16" diameter magnet has worked just fine. Link to comment https://bolterandchainsword.com/topic/323384-putting-magnets-in-the-bc-combi-weapons/#findComment-4426157 Share on other sites More sharing options...
Chesco Posted June 22, 2016 Author Share Posted June 22, 2016 @Major: I had not considered that approach. I will give it a try, Link to comment https://bolterandchainsword.com/topic/323384-putting-magnets-in-the-bc-combi-weapons/#findComment-4426484 Share on other sites More sharing options...
Quixus Posted June 22, 2016 Share Posted June 22, 2016 Please post pictures, if youtry and succeed Link to comment https://bolterandchainsword.com/topic/323384-putting-magnets-in-the-bc-combi-weapons/#findComment-4426495 Share on other sites More sharing options...
WarriorFish Posted June 23, 2016 Share Posted June 23, 2016 I'd say 1x1mm is perhaps too small, but a thin magnet should fit neatly? Link to comment https://bolterandchainsword.com/topic/323384-putting-magnets-in-the-bc-combi-weapons/#findComment-4427036 Share on other sites More sharing options...
Major_Gilbear Posted June 23, 2016 Share Posted June 23, 2016 Well, you could 1.5 x 1.5 (size of the Bolter muzzle drillbit) if you felt it necessary, but it's not really holding any weight and smaller is easier (and tidier) to fit. Link to comment https://bolterandchainsword.com/topic/323384-putting-magnets-in-the-bc-combi-weapons/#findComment-4427144 Share on other sites More sharing options...
Major_Gilbear Posted June 23, 2016 Share Posted June 23, 2016 In fact, I'd go for a ferrous metal pin in the nozzle, and a magnet in the gun casing. This lets you "slot" the muzzle into the gun casing, and the magnet stops it from sliding out again unless you pull it gently. :) Link to comment https://bolterandchainsword.com/topic/323384-putting-magnets-in-the-bc-combi-weapons/#findComment-4427149 Share on other sites More sharing options...
