Tribune rules?
There is a small datasheet for him that comes with the model.
The Tribune doesn't get any new special rules though, and his gear is simply adjusted to represent what's on the model.
If you were to 'build' him yourself as per the army list, you'd just select a Praetor, then upgrade him with Tartaros armour with combi-bolter, digital lasers, a master-crafted paragon blade and an iron halo.
Then he loses out on the combi-bolter (leaving him with no ranged weapon) and you deduct the cost of a standard assault legionnaire from the points total to figure out the Tribune's cost. Et voila.
https://bolterandchainsword.com/topic/323569-tribune-rules/#findComment-4431891
What is the army list mechanic behing the bold bit?  I had built him and was coming up with more points than the tribune's datasheet so i was wondering what i was doing wrong.
https://bolterandchainsword.com/topic/323569-tribune-rules/#findComment-4431911
Ah, i understand what you meant now.  I thought when you said you deduct the point cost of X that you pulled that from some existing convention of list building, rather than simply noting the difference in point cost between the Tirbune and a similarly equiped Praetor.  So the tribune is in fact a point discounted praetor at the expense of his ranged weapon.
https://bolterandchainsword.com/topic/323569-tribune-rules/#findComment-4431931
Wrong, GW stores all had datasheets in.
Mine did not have 40k Datasheets. It has been prominently stated, that the 40k Datasheets were created by a GW store staff member and shared with a few local GW shopfronts. They are NOT from GW proper and aren't "Official Rules" .
https://bolterandchainsword.com/topic/323569-tribune-rules/#findComment-4432133
