Finding the right highlight colors
Khulu
I'm having a hard time with this. I am painting my Admech Mechanicus Standard Gray and Kantor Blue. The way the display shelf was set up at my FLGS, it looked like I should use Dawnstone and Maccrage Blue, respectively.
The dawnstone ended up looking too bright, I think, and it looks like there should be something in between, but I don't know what. Conversely, the Macragge blue is almost the exact same shade as the Kantor Blue so it doesn't look like it's highlighted unless it's right under a light bulb. Is there a way to find a better match for these colors without just buying more paints to to try them?
Without buying more colours? Mix Mechanicus Standard and Dawnstone to get a suitable middle tone, and mix Macragge with Dawnstone to get a lighter (even if duller) blue. If you have white, you might consider mixing it with Macragge, to get a brighter light blue. Or you might wash Kantor with Nuln Oil to darken it before highlighting with Macragge.
Edit: Ops, sorry, I misread your post and thought you wanted to find a way to use those colours without buying more paints.
Just make sure to keep a note of your mix ratios, for example: 2 brushloads of Kantor to 1 brushload of Dawnstone.
Also making a little swatch of the colour next to the note will help you keep mixes consistent thumbsup.gif
Edit: Also what the Grand Master says is applicable :lol:
Altdorf and Calgar Blue are what i use for 1st and 2nd layer highlights on Maccragge Blue. Altdorf is a pretty subltle highlight and the calgar works nice for the areas you want to really bring up.
Below is how it looks on one of my world eaters
