Can deathshroud make sweeping advances?
While that would be the case, the FAQ makes a point of using the physical models to determine what type of suit they're wearing when its not specified:
If a unit has the option of taking Terminator armour but does not specify a particular pattern, such as the Legion Terminator Squad entry, its pattern is that represented on the physical models used, and only a single type of Terminator armour may be chosen for the unit when included in your army.
Which means that Deathshroud are one of the few Legion specific terminators that can be either Tartaros or Cataphractii based on which models you use to build them?
Yes, but word from the Open Day is that they're Tartaros when someone asked.
