Ovidius Incertus Posted July 27, 2016 Share Posted July 27, 2016 Can the liquid "brush on" Dullcote safely be sprayed through an airbrush to give more control than the rattlecan version? What cleanup method is best? I've got some Alclad lacquer cleaner. Good enough? Link to comment https://bolterandchainsword.com/topic/324221-spraying-testors-dullcote-through-an-airbrush/ Share on other sites More sharing options...
Bloody Legionnaire Posted July 27, 2016 Share Posted July 27, 2016 I am not aware of any "liquid 'brush on' dullcote." If you're talking about just regular testors dullcote that comes in a bottle and is lacquer based.. yes you run that through an airbrush. You will have to thin it with Lacquer thinner though... Link to comment https://bolterandchainsword.com/topic/324221-spraying-testors-dullcote-through-an-airbrush/#findComment-4451553 Share on other sites More sharing options...
Duymon Posted July 27, 2016 Share Posted July 27, 2016 And obviously you only want to be spraying a lacquer-based dull-coat over lacquer-based paint too :D As lacquer's tend be be a little too strong for me you might want to consider something like Future-Floor polish mixed with Tamiya Flat Base. It's mega easy to thin with water and painless to clean up as it's water-based. You may have to look for a different product that contains the same formula as future, based on your country though. Link to comment https://bolterandchainsword.com/topic/324221-spraying-testors-dullcote-through-an-airbrush/#findComment-4451939 Share on other sites More sharing options...
Bloody Legionnaire Posted July 27, 2016 Share Posted July 27, 2016 And obviously you only want to be spraying a lacquer-based dull-coat over lacquer-based paint too As lacquer's tend be be a little too strong for me you might want to consider something like Future-Floor polish mixed with Tamiya Flat Base. It's mega easy to thin with water and painless to clean up as it's water-based. You may have to look for a different product that contains the same formula as future, based on your country though. This is not true. Link to comment https://bolterandchainsword.com/topic/324221-spraying-testors-dullcote-through-an-airbrush/#findComment-4451976 Share on other sites More sharing options...
Ovidius Incertus Posted July 28, 2016 Author Share Posted July 28, 2016 I will be coating with Future as a final step before Dullcote, so I should think I'll be OK. Link to comment https://bolterandchainsword.com/topic/324221-spraying-testors-dullcote-through-an-airbrush/#findComment-4452270 Share on other sites More sharing options...
Bloody Legionnaire Posted July 28, 2016 Share Posted July 28, 2016 I will be coating with Future as a final step before Dullcote, so I should think I'll be OK. As long as you are airbrushing you will be more than fine using dullcote. I've used lacquer based varnish for years on models painted with enamels and never had an issue. If you want to be on the safe side, after you give your minis a few coats of gloss varnish, let the minis set for a day then hit them with the dullcote. That way they'll be fully hardened. Airbrushing is way less risky than hand brushing. Link to comment https://bolterandchainsword.com/topic/324221-spraying-testors-dullcote-through-an-airbrush/#findComment-4452314 Share on other sites More sharing options...
