Jackalwolf Posted August 3, 2016 Share Posted August 3, 2016 Hey all, It seems unfortunately it might be time to change my compressor. My current one has performed quite well with low noise levels but for the last months it has been building up too much moisture and the PSI pressure seems to have dropped, since the regulator doesn´t work that well anymore and PSI in rest state doesn´t build up beyond 30. This is my current compressor, from Grex: http://www.grexusa.com/grexairbrush/products.php5?id=AC1810-B http://www.grexusa.com/grexairbrush/pics/m_AC1810-B.jpgType: Piston Type CompressorHorse Power: 1/8 HPDisplacement: 0.7 cfmMax. Pressure: 60 psiWeight: 4.98kgNoise Level: 55dB It´s on the mid/premium side of compressors, at around $200 (£190 pounds since there are no local dealers and you have to pay shipping and tax) and it´s quite silent indeed, and to be honest I haven´t missed a tank too much since it´s really silent and the pressure was stable until the regulator presumably broke.That said, I do want to try one with a tank for my next one but I don´t want something massive and I do want a premium silent compressor, so I was looking at the following from Iwata: http://www.iwata-medea.com/products/compressors/tubular-compressors/tubular-compressors-smart-jet-plus/http://www.iwata-medea.com/wp-content/uploads/legacy/uploads/iwata-airbrush-compressors-tubular-compressors-smart-jet-plus-main.pngType: Piston Type CompressorHorse Power: 1/6 HPDisplacement: 0.81 cfmMax. Pressure: 60 psiWeight: 5.50kgNoise Level: 54dBTank: 0.45 liter It clearly outperforms my current compressor in all aspects, with 1 dB less, more HP, same PSI, and a tank of 0.45 liters which should be more than enough for my miniatures. Plus it´s compatible with all my airbrush accessories so it will be plug and play. The only con is the price, clocking in at a minimum of £264 ($350). Anybody would recommend against it? Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/ Share on other sites More sharing options...
Major_Gilbear Posted August 3, 2016 Share Posted August 3, 2016 Have you considered trying to get your Grex repaired? It seems likely to be a lot cheaper than buying a new one, and it could be a simple fix like fitting a new regulator... Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456688 Share on other sites More sharing options...
nefarious squirrel Posted August 3, 2016 Share Posted August 3, 2016 I can recomend the Iwata smart range even if there pricey. I had one for 6 years until it had an accident. I used it on and off during that period, and was good for consitentcy I replaced it with a sparmax tc-620x wich has a tank and two hose points. Its proved very powerful with a good range of control for the psi. A bit cheaper, but sparmax make compressors for other makes rebranded and are good quality. Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456690 Share on other sites More sharing options...
Jackalwolf Posted August 3, 2016 Author Share Posted August 3, 2016 Major, I purchased a cheap regulator to see if there´s any difference since changing the whole regulator unit would cost me 80USD plus shipping plus tax, which would be circa 90 GBP when all is said and done for something that might not solve the issue. I wish Grex had EU stockists but it´s a problem. Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456741 Share on other sites More sharing options...
Major_Gilbear Posted August 3, 2016 Share Posted August 3, 2016 Well I was more thinking taking it to a repair centre in London? Google shows lots of places and companies that service and repair such equipment (regardless of what the compressor is for), so I would think you'd have somebody nearby you that you can at least call? I mean, it's not like it's (1) in warranty, or (2) they'll break it more than it is already. - at the *worst*, it will cost you a couple of hours on a wasted trip. Then again, I suppose suggesting a repair rather than buying a new compressor probably shows my age! Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456745 Share on other sites More sharing options...
Jackalwolf Posted August 3, 2016 Author Share Posted August 3, 2016 I actually hadn´t thought about that option lol. If I can´t sell my SoH force I´ll look into that option! Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456747 Share on other sites More sharing options...
Major_Gilbear Posted August 3, 2016 Share Posted August 3, 2016 Well, it seems a shame to sell your force rather than trying to repair the compressor first- especially the Maloghurst based on a LE model... Still, it's your call! :) Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456749 Share on other sites More sharing options...
Jackalwolf Posted August 3, 2016 Author Share Posted August 3, 2016 The second reason is that I want to start a Vlka Fenryka army and a non astartes army (solar auxilia or DKOK) and I´m definitely keeping around the EC, but I don´t want to have that many projects in my plate plus the SoH speartip war style is quite similar to the Rout's drop down and :cuss things up leitmotif. Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456756 Share on other sites More sharing options...
Bat33.1 Posted August 3, 2016 Share Posted August 3, 2016 When I needed a replacement for my non tank compressor, I bought a generic AF186 compressor with a 3L tank from ebay, but you can find them on Amazon and lots of other places. It looks very similar to some of the name brand offered ones and has performed flawlessly for over two years now and I paid around £70 delivered. They seem to be about £80 now but anyway here are the listed details. Listed noise level is way lower than either of the two you have details from, 10dB is equivalent to doubling the volume. Output 1/5 hp (150W)Rotation speed 1450 / 1700 rpmStandard volume 23 l/minPressure setting range 0 - 4barAdjustment range on: 2,0bar off:4,0barActual operating pressure in continuous operation 0,35 - 2,5barMax. pressure 6,0barTank capacity 3 lHose connection 1/8 inch 9 mmCable length 1,9mNozzles suitable for all types of airbrush with nozzles 0,2 - 1,0mmDimensions 310 x 135 x 350mmWeight 5,2 kg (light and portable)Noise ca. 45 dB (low noise level)Overheat protection availableShutdown start / stop automatic Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456768 Share on other sites More sharing options...
Jackalwolf Posted August 3, 2016 Author Share Posted August 3, 2016 Interesting! Would you be able to provide a link to study it? Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456784 Share on other sites More sharing options...
Major_Gilbear Posted August 3, 2016 Share Posted August 3, 2016 Here you go (link). Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456791 Share on other sites More sharing options...
Jackalwolf Posted August 3, 2016 Author Share Posted August 3, 2016 Thank you so much! I´ll definitely go that route if I finally don´t sell the SoH army :) Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4456795 Share on other sites More sharing options...
Brother-Chaplain Kage Posted August 4, 2016 Share Posted August 4, 2016 It doesn't go above 30 PSI in rest state but what about when you're spraying? I usually spray in the 15-20 range, and only occasionally go as high 25. Link to comment https://bolterandchainsword.com/topic/324406-advice-with-airbrush-compressor-heresy-advice/#findComment-4457259 Share on other sites More sharing options...
