dtse Posted August 5, 2016 Share Posted August 5, 2016 here's a question about hit and run. It says pick a direction. Does that mean you have to move in a straight line? Do you have to move what you roll? For example if you roll 12 can you just move 9? What if you hit impassable terrain? It says ignore unit you in combat with. So can you move straight through them? Link to comment Share on other sites More sharing options...
Chaplain Lucifer Posted August 5, 2016 Share Posted August 5, 2016 Yes, you have to move in a straight line, the number told by the dice. Impassable terrain is impassible so you have to go round, trying to respect your direction as much as possible. And yes, you can go through the unit you were in combat with. Link to comment Share on other sites More sharing options...
dtse Posted August 5, 2016 Author Share Posted August 5, 2016 So if you move 6" and Ito anther enemy unit can you use the rest of your movement to curve around them or is that invalid? And can you go through friendly units Link to comment Share on other sites More sharing options...
