Custom Chaos lightning claws
Sick of buying Terminator Lord boxes just for the lightning claws because they're always out of stock on bitz sites? Doktor von Svartmetall has the cure!
For this, you will need 3 Spawn spiny bits, and any power fist of your choice. The pint of Carlsberg Export is optional biggrin.png
http://img.photobucket.com/albums/v218/Svartmetall/Tutorial/DSCF1488.jpg
First, trim the fingers off the power fist so you have a smooth surface where they once were:
http://img.photobucket.com/albums/v218/Svartmetall/Tutorial/DSCF1489.jpg
Next, trim the bases of the spines:
http://img.photobucket.com/albums/v218/Svartmetall/Tutorial/DSCF1490.jpg
And - in an unexpected plot twist - glue the spines to the fist; if you're paranoid like me, pin them too:
http://img.photobucket.com/albums/v218/Svartmetall/Tutorial/DSCF1493.jpg
I've put the spines in an even, level position for the purposes of this tutorial, but obviously you could have them in all sorts of angles depending on how you trimmed the base of the spines. Also, I'd recommend using a tiny bit of green stuff to smooth the joins between the spines and the body of the power fist.
Voila! A perfectly decent lightning claw for your Chaos Terminators; here it is in situ on one of my test-bed Plague Terminator torsos:
http://img.photobucket.com/albums/v218/Svartmetall/Tutorial/DSCF1494.jpghttp://img.photobucket.com/albums/v218/Svartmetall/Tutorial/DSCF1495.jpg
And if you want a matching pair, you can do it like this (hurriedly blu-tacked onto another one of my long-suffering test-bed Terminator torsos for photographic purposes):
http://img.photobucket.com/albums/v218/Svartmetall/Warhammer/DSCF1970.jpghttp://img.photobucket.com/albums/v218/Svartmetall/Warhammer/DSCF1971.jpg
http://www.heresy-online.net/forums/images/smilies/smile3.gif
Basically, take the original power fist and very carefully cut off the bits that you'd need to reverse to make a right-handed claw...then glue them back on in the appropriate places. I've not yet green-stuffed these bits in so they blend in smoothly with the rest of the fist (too many other modelling priorities at the moment) but hopefully these shots should give you the general idea. Seriously badass-looking these-are-gonna-:cuss-your-:cuss-up lighting claws biggrin.png
Hope this helps http://www.heresy-online.net/forums/images/smilies/smile3.gif
_____
https://bolterandchainsword.com/topic/324562-custom-chaos-lightning-claws/
What's Relic in this context.
The old Relic (videogame developer) news forums, where I was most active before it started slowing down after Space Marine and I jumped to B&C. It's been essentially dead since Relic folded.
http://forums.relicnews.com/forumdisplay.php?101-Warhammer-40-000-Tabletop-Discussion
