Cerastus Knight-Atrapos in War Machine Detachment
Can I take Cerastus-Atrapos (or two) in War Machine Detachment?
According to the new Legiones Astartes Red book there is nothing prohibiting it, however the red box in Atrapos profile (In book 6: Retribution) indicates that it "may be used either as part of a Mechanicum Taghmata army as LOW choice as normal or as a part of Questoris Knight Crusade Army as a 0-1 choice per 2000 points in the army"
I brought this up earlier. No, you can't take an Atrapos in a Legion list, Solar Auxilia List, or Imperialis Militia list.
In the rules for taking War Machine Detachments, it specifically says you can take Knights from the Questoris Knights army list. But the Atrapos entry (which is in the Questoris Knights army list) says it's only available to Mechanicum and Questoris Knights, and you must abide by that rule too.
So rules from one source circumventing another ? What if you don't have that book... How would you ever know. The implication being you must have every book now. Seems a bit muddled.
You need the Crusade Imperialis book to run Questoris Knights anyway, so what's your point?
As stated, if you want to field a knight you should at least have the rules for the knight.
The Atrapos can be found in the Mechanicum Crusade Imperialis red book and uh, book 5 I think? Both, afaik, limit his use to 1 per 2000 in a Mech or Knights army right in the unit entry. So unless there's something I missed in the LA:AoDAL book, I don't think he'd fit...
The Atrapos can be found in the Mechanicum red book and uh, book 5 I think? Both, afaik, limit his use to 1 per 2000 in a Mech or Knights army right in the unit entry. So unless there's something I missed in the LA:AoDAL book, I don't think he'd fit...
Just for clarification, the Atrapos is not in the Mechanicum red book or book 5, it's in book 6, Retribution.  And it's entry says it can be taken as a Mechanicum Taghmata army LoW as normal or as part of a Questoris Knight army as a 0-1 choice per 2,000 points.
Mechanicum Cerastus Knight - Atrapos
Boxed Rule on  the upper right of the entry page.
" The Mechanicum Knight - Atrapos may be used either as a part of a Mechanicum Thagmata army as a Lords of War choice as normal, or as part of a Questoris Knight Crusade army as a 0-1 choice per 2,000 points in the army."
The Horus Heresy Crusade Imperialis Army Lists
Page 114
The rules for the Knight in question  from  the most updated source make it clear  as to when you can and when you cannot take the night atleast from my reading.
Suffice to say  that if you are going to use a Knight - Atrapos you  should have this entry on  hand in order to appropriately field the Knight.
While the War Machine detachment allows for knights from the Questoris Knight list to be taken , the Atrapos is a special case that disqualifies it from being used in this manner.
The only way to Include a Knight Atrapos for minimal points would be to take an allied detachment  consisting of the Atrapos and another Knight  OR if you are playing traitors , the traitor Magos in the HQ slot and the Atrapos in the troop slot.
It is my personal opinion that taking the Knight along with another one as an allied detachment is stronger than taking it in a warmachine detachment as you can slot the Atropos as your HQ and taking two Knight Chassis is better than taking one.  But of course your mileage may Vary.
