Right handed pointing power fists (PA)
Right handed Space Marine power fist, pointing; the Assault Squad version is the only one I know of.
However, if you trim the finger off a closed right fist, it's actually quite easy to add the finger back in a pointing position using small pieces of trimmed sprue to build up the finger segments (or use the finger cut from the Assault Squad fist, or even the ones cut from the two Devastator left fists!). The benefits of plastic for conversions, right? ;)
The last edition of the Assault Marine Sprue had a right-armed pointing power fist.
http://ecx.images-amazon.com/images/I/51x2VVx9lhL.jpg
I don't know of any other pointing right-handers.
It's getting harder to track own these older assault boxes but it'd be well worth your time if you want that power fist.
Are there any others than the one in the Assault squad? I'm ideally looking for one with closed fingers like the left handed one in the Devastator squad box.
Thanks!
Original post.
@Duymon - Did you even read the original post?
