Thoughts On That Conversion Idea
Well, Missile Launcher Marines Used To Use The Generic BackPacks.
The More Recent Marines With Missle Launchers Seem To Have That Grabber Claw Big BackPack.
That Claw Resembles A Tech Marine Sort Of.
So One Idea Was To Use That As A Tech Marine Claw, And Cover The Rest Of The BackPack In Purity Seals To Hide The Missile Launcher Side And Aspects.
Thoughts On That Idea?
https://bolterandchainsword.com/topic/324751-thoughts-on-that-conversion-idea/
As a Forge Mod, I will say that your text would be a lot easier to read if you would use a normal writing convention. Per the B&C Rules, while we understand that English is not every member's first language, all members should post in as legible a manner as possible. Legibly written posts get more responses.
For the conversion suggestion: you used to be able to get the missile loader claw as a separate bit, so you'd be a lot better off trying to get several and converting them as small servo-arms on a single model (four on a single pack reaching forward, etc). I agree with Scion of Ferrus, a single missile loader claw looks far to dinky to look like it should count as a full servo-arm alone.
That said, it's your models, and as long as your standard opponents are cool with it, go for it. There have got to be some better options than simply covering the rest of the pack in purity seals just to cover up the missiles.
