Assembling Chimera
Hey guys,
I'm assembling my first chimera and i've encountered an issue. Everything is fine except the multi-laser "nozzle" which from the assembly manual seems to be hollow, is one solid piece. Any advice on fixing this, i'm thinking of just drilling it, but i wanted to ask you guys first.
https://bolterandchainsword.com/topic/324789-assembling-chimera/
Do you mean the slightly angled end of the gun? If so yes that should be hollow so you can slot it on (right side up of course!), so it sounds like you need to drill it out. To be on the safe side post a picture up if you can so we can double check thumbsup.gif
Hmm, maybe your kit got past QC, it happens. I've had kits missing bases but never anything on that level.
I opened the other Chimera kit that i got and it has the same issue. Doubt its enough to call GW support over such an issue
sorry for potato, quality. http://imgur.com/a/3bHka
It says the link doesn't work, vilain. It could be a user problem on my end but I've tried it twice.
