Don't bother buying them, just convert them yourself couldn't be simpler! The standard deathwatch boltguns already look pretty similar to stalker boltguns all i'd do is buy some plastic rod cut it to the same length as the silencer thing on the stalker bolter that comes in the kit, glue or pin it on and then voila! If you want to you can cut down the magazine to match aswell.
I've used the Grey Knight Interceptor backpacks.  Just cut off the little rods, flatten the ends and drill it out.
This picture isn't the best angle, but you get the idea.
http://i1352.photobucket.com/albums/q655/SlickJsax/DSC_0161_zpssgkv3dg4.jpg
Huh, that is actually very nice idea, I might steal it!
I look at the Recon picture Slipstream linked and have no idea how having that as an example GW sculptors came up with such comically stupid idea as DW stalker bolter. Not only the suppressor looks haphazardly glued on the end, thanks to being blocked by sticking out bits, the bolter barrel holes are actually visible in front of the suppressor negating whatever function it might have had. It literally looks like someone took 3D file of normal bolter, slapped cylinder on it lazily without changing anything, and called it a day...
Register a new account
Sign in
