Vanquisher vs Annihilator
in my experience the range doesn't matter that much and 48" is more then enough, and twin linked is sorely needed with BS3. on the other hand the vanq is better versus AV14. so its a toss up based on if you encounter more xenos or other imperials who bring the AV14.
48" is plenty as mentioned, and aside from the tank being a bit left behind rules wise as nice as twin-linking is Guard can get lascannons easily enough elsewhere. On a tank I'd rather go with something more specialised so I'd have a Vanquisher over an Annihilator. It gives you some real armour opening power especially if you put a tank commander in (or Pask!).
Against AV 14:
A Annihilator has a 75% chance to hit, followed by a 16,67% chance to penetrate = 12,5% chance to penetrate AV 14.
A Vanquisher has a 50% chance to hit, followed by a 58,34% chance to penetrate = 29,7% chance to penetrate AV 14.
Against AV 13:
A Annihilator has a 75% chance to hit, followed by a 33,33% chance to penetrate = 24,9% chance to penetrate AV 13.
A Vanquisher has a 50% chance to hit, followed by a 72,23% chance to penetrate = 36,1% chance to penetrate AV 13.
Against AV 12: ...use Autocannons. ;)
I'd take the Vanquisher.
