Chaplain Raeven Posted November 1, 2016 Share Posted November 1, 2016 You get 5 spare torsos with your assault dudes. Scavenge some legs somewhere and use the remaining heavies. Or magnetise the torso. It's easier than the weapons. You should have enough helmets already. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4550411 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 1, 2016 Author Share Posted November 1, 2016 Yea i only have one set of legs that weren't used so far and that was in a assault marine pose. Its fine i'll just get more guys if its too hard for the backpacks. Extra Torsos : Check Extra Heads : Checkity Check Extra Legs: BIG BUZZZZERRRRRR Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4550413 Share on other sites More sharing options...
Chaplain Raeven Posted November 1, 2016 Share Posted November 1, 2016 Oh well, put some magnets between the legs and torsos, so you can switch a tactical with a dev. Or check out the bitz shops. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4550424 Share on other sites More sharing options...
Major_Gilbear Posted November 1, 2016 Share Posted November 1, 2016 Or... Get a set of cheap DV Tacticals, and chop them at the waist. ;) Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4550629 Share on other sites More sharing options...
JeffJedi Posted November 1, 2016 Share Posted November 1, 2016 Buy command squads and get an extra pair. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4550843 Share on other sites More sharing options...
elmo Posted November 1, 2016 Share Posted November 1, 2016 I have the feeling that you're overthinking it all tbh. Elmo would probably disagree, but magnetising everything isn't always a good thing. Oh yes it is.... Actually I only ever magnetised the bases on the scouts which came with the LS Storm but that was so I could mount them in the vehicle too ;) In principle it is reasonably easy to magnetise backpack/Jump packs on the assaults but it is not something I would consider - as already said just tell your opponent that they are "counts as" standard packs for that game. HW are far too much hassle apart from rocket launchers and HH heavy bolters to magnetise. If you have spare torsos then you could go down the torso swapping route. I always seem to have extra torsos lying around - you can even use the vehicle commander with little extra work, just magnetise/pin at the waist. Darkn3ssF4lls 1 Back to top Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4550879 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 2, 2016 Author Share Posted November 2, 2016 I have the feeling that you're overthinking it all tbh. Elmo would probably disagree, but magnetising everything isn't always a good thing. Oh yes it is.... Actually I only ever magnetised the bases on the scouts which came with the LS Storm but that was so I could mount them in the vehicle too In principle it is reasonably easy to magnetise backpack/Jump packs on the assaults but it is not something I would consider - as already said just tell your opponent that they are "counts as" standard packs for that game. HW are far too much hassle apart from rocket launchers and HH heavy bolters to magnetise. If you have spare torsos then you could go down the torso swapping route. I always seem to have extra torsos lying around - you can even use the vehicle commander with little extra work, just magnetise/pin at the waist. Thank you for your experience, haha may have gone magnet crazy trying to maximize every nook and crany haha! Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4551225 Share on other sites More sharing options...
Chaplain Raeven Posted November 2, 2016 Share Posted November 2, 2016 (edited) Elmo would probably disagree, but magnetising everything isn't always a good thing. Oh yes it is.... Called it Edited November 2, 2016 by GreyRavenC elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4551266 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 2, 2016 Author Share Posted November 2, 2016 My questions are endless! My mind is not illuminated with knowledge, ugh. So to make a combi something, do I just hack up this bolt gun and add that plasma looking piece to it ? I don't see anything that screams that its already in this fashion. http://i.imgur.com/MAGr4TOm.jpg What is this thing on the left is that some kinda grenade in hand? http://i.imgur.com/mKZADOZm.jpg Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552174 Share on other sites More sharing options...
Chaplain Raeven Posted November 2, 2016 Share Posted November 2, 2016 Wait, no combi-weapons in the kit? That can't be right... The thingy in the hand is a scanner. You could use it as auspex, I use it as decoration Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552191 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 2, 2016 Author Share Posted November 2, 2016 Wait, no combi-weapons in the kit? That can't be right... The thingy in the hand is a scanner. You could use it as auspex, I use it as decoration Maybe I put it in the heavy weapons box I'll check that when I get back, thanks GrayRaven. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552201 Share on other sites More sharing options...
Chaplain Raeven Posted November 2, 2016 Share Posted November 2, 2016 Games Workshop Check the link above. On the second sprue, you can find the bolterpiece on the 2nd sprue, at the bottom right (next to the pads). The pieces that are supposed to be mounted on there are on the 3rd sprue, center right (next to the torse with groinprotection). The sarge on the cover demonstrates how it should look like complete. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552248 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 2, 2016 Author Share Posted November 2, 2016 Games Workshop Check the link above. On the second sprue, you can find the bolterpiece on the 2nd sprue, at the bottom right (next to the pads). The pieces that are supposed to be mounted on there are on the 3rd sprue, center right (next to the torse with groinprotection). The sarge on the cover demonstrates how it should look like complete. Aha! Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552290 Share on other sites More sharing options...
Major_Gilbear Posted November 2, 2016 Share Posted November 2, 2016 I hope that you kept the assembly instructions - they are normally pretty good at explaining things like Combi-weapons. ;) Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552319 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 2, 2016 Author Share Posted November 2, 2016 I hope that you kept the assembly instructions - they are normally pretty good at explaining things like Combi-weapons. I hope that you kept the assembly instructions - they are normally pretty good at explaining things like Combi-weapons. ya i got them, it doesn't seem to difficult the issue is there's only two bolter bases :/ looks like i'll have to magnetize the combi ? or just not worth it and get some more bases off of the internet Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552355 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 3, 2016 Author Share Posted November 3, 2016 Ended up just putting them together lol the arm is magnatized cause he's a Sgt so should be easy Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552396 Share on other sites More sharing options...
Chaplain Raeven Posted November 3, 2016 Share Posted November 3, 2016 There should be no shortage of combi's online. B@C even has 3 of them in the box. You could always count-as the combi as another version until you find your prefered gunz. I usually take Combi-flamer on Assaults, combi-plasma on Tacticals, Combi-gravs on Command and combi-melta/plasma on guys in pods/rhino's. Although I must confess, I gave my devastators a combi-grav purely because it looked awesome... Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552517 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 3, 2016 Author Share Posted November 3, 2016 There should be no shortage of combi's online. B@C even has 3 of them in the box. You could always count-as the combi as another version until you find your prefered gunz. I usually take Combi-flamer on Assaults, combi-plasma on Tacticals, Combi-gravs on Command and combi-melta/plasma on guys in pods/rhino's. Although I must confess, I gave my devastators a combi-grav purely because it looked awesome... Hmm that makes that box even more tempting! Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552711 Share on other sites More sharing options...
Chaplain Raeven Posted November 3, 2016 Share Posted November 3, 2016 (edited) If you'd buy a whole box for a couple of bits, be my guest. But don't be afraid of ebay or Bitz-stores, like the one linked below. Combi-BITZ Edited November 3, 2016 by GreyRavenC Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552737 Share on other sites More sharing options...
Major_Gilbear Posted November 3, 2016 Share Posted November 3, 2016 There should be no shortage of combi's online. B@C even has 3 of them in the box. Four combi weapons if you count the Terminator Captain's combi melta! ;) @ Darkn3ssF4lls: I PM'd you a list of the best boxes to get combi and special weapons in the other day. Bits-sellers (or third party manufactures) are very popular alternatives to buying the full kits. of course, it still helps to know what kits the parts are in, hence the list I'd sent you. If you do a Google image search for "combi weapon alternatives", you'll find rather a lot of options too - including how to convert the spare parts you already have into more combi weapons. For example, the Devastator kit comes with a stormbolter. If you cut one barrel off the stormbolter and add on the barrel of the spare combi part (flamer and meltagun work especially well for this conversion), you get a very effective combi weapon. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4552839 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 4, 2016 Author Share Posted November 4, 2016 There should be no shortage of combi's online. B@C even has 3 of them in the box. Four combi weapons if you count the Terminator Captain's combi melta! @ Darkn3ssF4lls: I PM'd you a list of the best boxes to get combi and special weapons in the other day. Bits-sellers (or third party manufactures) are very popular alternatives to buying the full kits. of course, it still helps to know what kits the parts are in, hence the list I'd sent you. If you do a Google image search for "combi weapon alternatives", you'll find rather a lot of options too - including how to convert the spare parts you already have into more combi weapons. For example, the Devastator kit comes with a stormbolter. If you cut one barrel off the stormbolter and add on the barrel of the spare combi part (flamer and meltagun work especially well for this conversion), you get a very effective combi weapon. Thanks brother, I will have to start getting these. In the meantime i will continue to assemble what I got haha. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4553400 Share on other sites More sharing options...
Major_Gilbear Posted November 4, 2016 Share Posted November 4, 2016 Well, as I said: you do have spare bits, so you can cut down a spare bolter to accommodate a leftover Combi-weapon component - pretty simple to do, and saves you buying more bits/kits. :) Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4553441 Share on other sites More sharing options...
Darkn3ssF4lls Posted November 4, 2016 Author Share Posted November 4, 2016 (edited) Well, as I said: you do have spare bits, so you can cut down a spare bolter to accommodate a leftover Combi-weapon component - pretty simple to do, and saves you buying more bits/kits. :)More kits more bits, FYI I'm seeing the err in the magnetizing the feet haha about to scrape off the bottom magnets and glue them down to the base haha. Sacrificing the ones in the feet. Trying to decide if my watcher would be of caliban or mortikah Concept Change idea Was thinking of basically being the Legion too (changing my design concept). So like Raven and green would be the covenant. Yet the leaders of the group would be just names on paper for the high lords benefit. In reality they would be the inner circle ( not company masters, they would be real) Then first company would be green, gray, black, etc to signify allegiance. So when I play in campaigns it would be as if all of the Dark Angels legion was present. I would only have one squad of each than the rest would be GoTC What do you think ? Too dramatic ? Edited November 4, 2016 by Darkn3ssF4lls Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4553446 Share on other sites More sharing options...
Darkn3ssF4lls Posted December 20, 2016 Author Share Posted December 20, 2016 What would be best to put 60 ish bucks in to expand this holiday season ? I'm thinking something to get me in the path to a full company ? Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4597633 Share on other sites More sharing options...
Greenz Posted December 20, 2016 Share Posted December 20, 2016 What would be best to put 60 ish bucks in to expand this holiday season ? I'm thinking something to get me in the path to a full company ? Are you thinking for Christmas, or shortly after? The new tactical squad and rhino/ drop pod boxes are being released on the 31st of December. Im not sure if the prices have been let out yet, but youre probably looking around there. What currency? Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/10/#findComment-4597641 Share on other sites More sharing options...
