BlackTriton Posted September 21, 2016 Share Posted September 21, 2016 (edited) I have found this to be true first hand (the clogging of details that is). I used spray primer from a rattle can for years, and was shocked at how much better even a cheap air brush can lay down a thin even coat of primer. I have moved to almost exclusively using primer sprayed from an air brush. I know that is not an option for everyone though. You can get good results from a spray can though, just be careful about overdoing it. indeed, less is more with spray can. or so I have learn. I dosent mater if the primer is not equal, better keep it thin. Edited September 21, 2016 by BlackTriton Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4509557 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 21, 2016 Author Share Posted September 21, 2016 I used it once, its pretty much an equivalent to ledbelcher from citadel range. I guess its what I would use to basecoat Guardian of the covenant quickly. although, spray paint is the best way to clog details, be carefull! I have found this to be true first hand (the clogging of details that is). I used spray primer from a rattle can for years, and was shocked at how much better even a cheap air brush can lay down a thin even coat of primer. I have moved to almost exclusively using primer sprayed from an air brush. I know that is not an option for everyone though. You can get good results from a spray can though, just be careful about overdoing it. I used it once, its pretty much an equivalent to ledbelcher from citadel range. I guess its what I would use to basecoat Guardian of the covenant quickly. although, spray paint is the best way to clog details, be carefull! I've had good results so far [for a novice], I'm no where near the level of buying a really expensive equipment to paint the models. Not to mention it would need to be 110 - 240. I've actually only started to experience clogging here at the end of my first can, it wont spray properly and then you shake and try to get it to cover and it then finally sprays what it has left haha. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4509558 Share on other sites More sharing options...
Malcifer Posted September 21, 2016 Share Posted September 21, 2016 (edited) When you are done spraying for a while, turn the can upside down and spry until the paint is out of the nozzle (usually not more than a second). This will keep your can of primer working until the last drop. Just be careful not to spray something by accident when clearing the nozzle (I have). Edit: Fixing punctuation. Edited September 21, 2016 by Malcifer Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4509560 Share on other sites More sharing options...
Major_Gilbear Posted September 21, 2016 Share Posted September 21, 2016 I use spray primer, and my models turn out fine. Aside from the usual advice on when/how to spray, I woyld suggest that you avoid hobby primers and use automotive primers instead. Much better, much thinner, less fickle to get a good result from. Cheaper too! :) Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4509697 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 21, 2016 Author Share Posted September 21, 2016 I use spray primer, and my models turn out fine. Aside from the usual advice on when/how to spray, I woyld suggest that you avoid hobby primers and use automotive primers instead. Much better, much thinner, less fickle to get a good result from. Cheaper too! What are we talking like 10 bucks cheaper and then you have to find one that matches your tint? Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510149 Share on other sites More sharing options...
Major_Gilbear Posted September 21, 2016 Share Posted September 21, 2016 Well, the they are primers - and you are supposed to paint over them. Normally when I use a primer (usually grey), I leave no primer visible when I'm done painting the model. Therefore matching tint or whatever is irrelevant really. If you're using a coloured primer to double up as your basecoat, then you don't really need to match the paints either; just use a suitable colour. So for silver, you can either use a bright silver and then wash it down, or a darker silver and highlight up. However, you will probably need to do two thing careful passes to avoid missing any spots or having a patchy basecoat (since the primer is doing both). If you buy a big brand name of automotive primer, it's trivially easy to just buy more of the same when you run out. The idea that your paints and primer need to somehow match is... A pretty artificial "problem" really. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510167 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 21, 2016 Author Share Posted September 21, 2016 (edited) Well, the they are primers - and you are supposed to paint over them. Normally when I use a primer (usually grey), I leave no primer visible when I'm done painting the model. Therefore matching tint or whatever is irrelevant really. If you're using a coloured primer to double up as your basecoat, then you don't really need to match the paints either; just use a suitable colour. So for silver, you can either use a bright silver and then wash it down, or a darker silver and highlight up. However, you will probably need to do two thing careful passes to avoid missing any spots or having a patchy basecoat (since the primer is doing both). If you buy a big brand name of automotive primer, it's trivially easy to just buy more of the same when you run out. The idea that your paints and primer need to somehow match is... A pretty artificial "problem" really. Haha ok, yea learn something new every day i do like the black especially when i'll have a big 1st and second company with lots of black lol. So i want to try this but am a bit intimidated about mucking it up. So should I be worried about trying to exacto that chain fist off so i can magnatize the model ? It would have the added benifit of not having to paint the terminator symbol through his Aquila on his chest haha. http://i.imgur.com/xzj9xp7m.jpg Thinking about doing it right at the base of the torso and the shoulder. Edited September 21, 2016 by Darkn3ssF4lls Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510363 Share on other sites More sharing options...
FlamingDeth Posted September 21, 2016 Share Posted September 21, 2016 It's typically more trouble than its worth to magnetize snap fit models, and its usually a good idea to have at least one chain fist in a terminator squad anyways. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510368 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 21, 2016 Author Share Posted September 21, 2016 It's typically more trouble than its worth to magnetize snap fit models, and its usually a good idea to have at least one chain fist in a terminator squad anyways. Doh ok, so I should basically paint the back separate from the front then put them together with superglue? Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510371 Share on other sites More sharing options...
FlamingDeth Posted September 21, 2016 Share Posted September 21, 2016 Up to you. The terminators don't have any bits really crossing over their bodies so it doesn't really complicate anything to have them assembled first. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510417 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 21, 2016 Author Share Posted September 21, 2016 Up to you. The terminators don't have any bits really crossing over their bodies so it doesn't really complicate anything to have them assembled first. These DV mini's have had tons of things that get covered up when you put them together, in the case of this guy his whole shoulder is covered up by a thing on the front of the torso. There was something similar with the Sergeant for the Basic Marines that I had to have his torso separate or i wouldn't be able to get to one of his shoulders. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510424 Share on other sites More sharing options...
Chaplain Raeven Posted September 21, 2016 Share Posted September 21, 2016 I agree with the Cardinal, Terminators are usually safe to assemble completely before assembly. The only exception would be with Heavy Weapons (those thighs become hard to reach then) Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510442 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 21, 2016 Author Share Posted September 21, 2016 Up to you. The terminators don't have any bits really crossing over their bodies so it doesn't really complicate anything to have them assembled first. Up to you. The terminators don't have any bits really crossing over their bodies so it doesn't really complicate anything to have them assembled first. These DV mini's have had tons of things that get covered up when you put them together, in the case of this guy his whole shoulder is covered up by a thing on the front of the torso. There was something similar with the Sergeant for the Basic Marines that I had to have his torso separate or i wouldn't be able to get to one of his shoulders. I agree with the Cardinal, Terminators are usually safe to assemble completely before assembly. The only exception would be with Heavy Weapons (those thighs become hard to reach then) This is example of the trouble area i am referring to, i just barley put it on there but it would be flush when its fully attached. So i'll take it back off and paint them separately haha. http://i.imgur.com/6o5hlQqm.jpg Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510454 Share on other sites More sharing options...
Chaplain Raeven Posted September 21, 2016 Share Posted September 21, 2016 That's a minor issue, to be honest. I painted the shoulder without regard for the winged shield. Then I painted the shield with a bit more caution. It's easier to paint carefully for 5 minutes than to keep the mini apart for the sake of a single spot. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510461 Share on other sites More sharing options...
Major_Gilbear Posted September 21, 2016 Share Posted September 21, 2016 If it bothers you, just cut the left arm where it meets the body, glue the torso to the front, and put pins in the arms - this lets you keep the arms (and shoulders) separate for painting. I personally don't think the wing covers the shoulder too badly, but if you want to check, whilst it's dry-fit assembled just get your brush without any paint on it and try it out - see what you think. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510463 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 21, 2016 Author Share Posted September 21, 2016 (edited) I see what your saying, I guess it doesn't matter what the back of the wing looks like for TT grade. [if i can call my stuff that ] Tried what you said Major, no way to get it in there unless your using a flat like really really fine brush. Edited September 21, 2016 by Darkn3ssF4lls Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510471 Share on other sites More sharing options...
FlamingDeth Posted September 21, 2016 Share Posted September 21, 2016 (edited) It might just be my predilection for painting second hand miniatures that are already assembled but I would hardly notice that winged shield. It's why you have troopers carrying giant guns cover two thirds of their chestplate that things get dicey. Edited September 21, 2016 by CardinalVirtue Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510537 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 22, 2016 Author Share Posted September 22, 2016 (edited) It might just be my predilection for painting second hand miniatures that are already assembled but I would hardly notice that winged shield. It's why you have troopers carrying giant guns cover two thirds of their chestplate that things get dicey. Hehe may be simple for some but defiently not the guy who can't even paint a line on the pads and not get the pad ! Results of Day 1 on the Terminators http://i.imgur.com/ByqOE2Om.jpg Edited September 22, 2016 by Darkn3ssF4lls Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4510730 Share on other sites More sharing options...
Darkn3ssF4lls Posted October 16, 2016 Author Share Posted October 16, 2016 A rhinozorback joins the fight http://i.imgur.com/4mDkTKzl.jpg Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4533550 Share on other sites More sharing options...
Malcifer Posted October 16, 2016 Share Posted October 16, 2016 If you are careful about what parts you glue in place this could be a Razorback or a Rhino depending on what you need on the day. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4533570 Share on other sites More sharing options...
Darkn3ssF4lls Posted October 16, 2016 Author Share Posted October 16, 2016 If you are careful about what parts you glue in place this could be a Razorback or a Rhino depending on what you need on the day. Aye thats the plan :/ lol! Got to watch some videos on that to make sure i get it right. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4533579 Share on other sites More sharing options...
Malcifer Posted October 16, 2016 Share Posted October 16, 2016 Really it is just the big doors on the top and perhaps the hatches. Everything else is the same. Fortunately, the Razorback comes with all the parts to make either. You can go even one step further. As long as you don't permanently glue in the side doors you could eventually use this for a Predator as well. I glued some large flat magnets into the door recesses and now I can put on either the Rhino doors or the Predator sponsons. A little looking around on ebay and you will eventually find the Predator sprews needed. Just a thought. Darkn3ssF4lls 1 Back to top Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4533589 Share on other sites More sharing options...
Darkn3ssF4lls Posted October 16, 2016 Author Share Posted October 16, 2016 Really it is just the big doors on the top and perhaps the hatches. Everything else is the same. Fortunately, the Razorback comes with all the parts to make either. You can go even one step further. As long as you don't permanently glue in the side doors you could eventually use this for a Predator as well. I glued some large flat magnets into the door recesses and now I can put on either the Rhino doors or the Predator sponsons. A little looking around on ebay and you will eventually find the Predator sprews needed. Just a thought. aha good to know, i just need my drill bits haha Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4533623 Share on other sites More sharing options...
Chaplain Raeven Posted October 16, 2016 Share Posted October 16, 2016 There isn't really much to be carefull about. Just refrain from glueing the following stuff: - Top square hatch - Razorback turret - The 2 individual hatches up top. It all fits snugly. So as long as you don't perform summersaults with the chassis (like a certain Tartaros Terminator), you'll be fine. Malcifer's sugestion for the hatches on the side is good, but I wouldn't bother. If you want the pieces for a predator, you'd have to buy the whole kit anyway. Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4533644 Share on other sites More sharing options...
Darkn3ssF4lls Posted October 16, 2016 Author Share Posted October 16, 2016 (edited) There isn't really much to be carefull about. Just refrain from glueing the following stuff: - Top square hatch - Razorback turret - The 2 individual hatches up top. It all fits snugly. So as long as you don't perform summersaults with the chassis (like a certain Tartaros Terminator), you'll be fine. Malcifer's sugestion for the hatches on the side is good, but I wouldn't bother. If you want the pieces for a predator, you'd have to buy the whole kit anyway. Couldn't one just buy the bits for the guns? or is the chasis bigger? Edited October 16, 2016 by Darkn3ssF4lls Link to comment https://bolterandchainsword.com/topic/325182-guardians-of-the-covenant-wip-darkn3ss-tale/page/7/#findComment-4533726 Share on other sites More sharing options...
