Darkn3ssF4lls Posted August 29, 2016 Share Posted August 29, 2016 Anyone have some suggestions for things the wife won't kill me to use to thin and mix paints with ? Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/ Share on other sites More sharing options...
Jolemai Posted August 29, 2016 Share Posted August 29, 2016 Depends on the amount, but you could make a wet pallet from a plastic takeaway tub. The info is online (maybe YouTube too) but it's basically a tub with a blister sponge at the bottom and a sheet of greaseproof paper on top. Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/#findComment-4483527 Share on other sites More sharing options...
Darkn3ssF4lls Posted August 29, 2016 Author Share Posted August 29, 2016 Ok kewl I was thinking I got a egg carton but don't have any suran wrap Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/#findComment-4483531 Share on other sites More sharing options...
Soldier of Dorn Posted August 29, 2016 Share Posted August 29, 2016 The other day I was at the local GW painting, and I had forgotten my pallet, so I just used an old WHFB rectangular base (like a 100x60, or something like that) but I don't use a wet pallet (even though I probably should.) So that is an option too, just use a larger base. Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/#findComment-4483535 Share on other sites More sharing options...
Darkn3ssF4lls Posted August 29, 2016 Author Share Posted August 29, 2016 Sadly for a public transport gimped person such as myself the GW is a bit far from the nearest metro and that's even if I'm on my bike. Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/#findComment-4483551 Share on other sites More sharing options...
Space Truckin Posted August 29, 2016 Share Posted August 29, 2016 chinese food takeaway container not cardboard box kind. the plastic ones, maybe try ordering the soup next time? also the Plastic Coolwhip containers = redneck tupperware. The lids work pretty well and won't be missed. Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/#findComment-4483553 Share on other sites More sharing options...
Major_Gilbear Posted August 29, 2016 Share Posted August 29, 2016 Use an old white saucer/small plate. If you don't have any, you can get one either from Ikea or such, or from your nearest charity/second hand store. White helps you see/judge colours best, and the shallow lip avoids the paint running off (like it can off when using a spare wall tile instead). Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/#findComment-4483624 Share on other sites More sharing options...
Darkn3ssF4lls Posted August 29, 2016 Author Share Posted August 29, 2016 Ended up getting some kewl boxes from container store that are tiny. Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/#findComment-4483816 Share on other sites More sharing options...
White Wolf Posted August 30, 2016 Share Posted August 30, 2016 I use white 6" x 6" bathroom tiles which you can buy from your local DIY store in the UK for a couple of pounds for a box of 10/20. You can clean them or bin them for that price. You can get wet palette paper in the UK from shops like "The Range" or Hobbycraft (more craft, less hobbies these days.... ) for a couple of quid a pad - that's the best stuff to put in a wet palette. I use an old VHS case for my wet palette with foam in the bottom. I also have a P3 wet palette as well - good but pricey compared to DIY options. ATB WW Link to comment https://bolterandchainsword.com/topic/325278-best-household-item-pallet/#findComment-4484178 Share on other sites More sharing options...
