Jamafore Posted September 1, 2016 Share Posted September 1, 2016 For a model of my brother's that needs repainting, I need to strip it. Problem is it's enamel paint. I know Simple Green strips acrylic, that's why I have some, but does it work the same on enamel paint? Link to comment https://bolterandchainsword.com/topic/325374-will-simple-green-strip-enamel/ Share on other sites More sharing options...
Son of Carnelian Posted September 1, 2016 Share Posted September 1, 2016 Should do just fine. I've seen Simple Green eat through some seriously heinous stuff but leave delicate models completely unscathed. Love the Green. Link to comment https://bolterandchainsword.com/topic/325374-will-simple-green-strip-enamel/#findComment-4486235 Share on other sites More sharing options...
Jamafore Posted September 1, 2016 Author Share Posted September 1, 2016 Ok Thank you. I didn't think that there would be too much issue, but I was unsure with the whole oil/water thing. Link to comment https://bolterandchainsword.com/topic/325374-will-simple-green-strip-enamel/#findComment-4486268 Share on other sites More sharing options...
Bloody Legionnaire Posted September 1, 2016 Share Posted September 1, 2016 You can use Testors paint thinner or just white mineral spirits to trip Enamels very easily... Link to comment https://bolterandchainsword.com/topic/325374-will-simple-green-strip-enamel/#findComment-4486286 Share on other sites More sharing options...
Major_Gilbear Posted September 1, 2016 Share Posted September 1, 2016 It can do, especially if the enamel paints are scuffed a little (to help the Simple Green work it's way through the primer under the enamel, thus lifting it off from underneath). If you find it's struggling, you can also try Dot 3/4 Clutch & Brake fluid (sold in Halfords if you're in the UK). This is not very kind to your hands/environment, but a glass jar of the stuff will strip a *lot* before it gets too thick/unusable, and most local garages are happy enough to dispose of the occasional glass jar of the stuff for you if you ask nicely. This stuff is good to use on plastics and metals (keep an eye on plastics though - maybe check on them every hour or so -as it can be rather harsh on the softer/older plastics). Finally, another plus-point for it is that it's not very volatile, so it doesn't give off lots of nasty fumes or anything. Link to comment https://bolterandchainsword.com/topic/325374-will-simple-green-strip-enamel/#findComment-4486412 Share on other sites More sharing options...
Claws and Effect Posted September 8, 2016 Share Posted September 8, 2016 Simple Green strips acrylic paint? Awesome to know! I have a handful of assault marines that have like 9 coats of paint on them Link to comment https://bolterandchainsword.com/topic/325374-will-simple-green-strip-enamel/#findComment-4494321 Share on other sites More sharing options...
Jamafore Posted September 8, 2016 Author Share Posted September 8, 2016 RealityBurn: the paint is usually gone after a day or 2 soaking, then giving it a good scrub. I've actually had more issues getting the primer off though. That takes a few more days then I'll leave it in clean water for a few days to make sure all of the simple green gets out of the model. Especially if we're talking something like a Rhino that is relatively hollow. Link to comment https://bolterandchainsword.com/topic/325374-will-simple-green-strip-enamel/#findComment-4495223 Share on other sites More sharing options...
