Sgt. Blank Posted August 24, 2018 Share Posted August 24, 2018 (edited) Wow, that thing is stunning! The paint work and conversion really complement each other well. I think my favorite bit may be the subtle contrast between the aged looking metal on the shoulder mounts and the black white and very armor plates, it works really well and shows a high level of skill in multiple techniques.Any tips on how to replicate the green stuff chaos trim? Its definitely worthy of emulating edit: correcting auto correct Edited August 25, 2018 by Sgt. Blank 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5152767 Share on other sites More sharing options...
Bjorn Firewalker Posted August 24, 2018 Share Posted August 24, 2018 Most impressive. Your painting skills are especially commendable and enviable. 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5153024 Share on other sites More sharing options...
Lasuria Posted August 24, 2018 Share Posted August 24, 2018 (edited) It's been quite some time since I've seen this plog. I see that it's still quite impressive ! The warlord is coming along quite nicely and you almost made me like the armiger model (but I will resist the temptation :')) But must of all the "datasmith" is awesome !While catching up I've seen a couple questions you didn't answered and I assume it's because of the language barrier so I'll translate them below for you (do not hesitate to ask if you need help answering ) Hidden Content Ça fait un certain temps que je ne suis pas passer sur ce post. Je constate que vous faites toujours du superbe boulot ! Le warlord avance vraiment bien et vous m'avez presque réconcilier avec le armiger (mais je résisterais a la tentation ! :')) Mais la "datasmith" est tout simplement splendide !En rattrapant mon retard j'ai noter quelques questions auxquelles tu n'a pas répondu, je suppose que c'est a cause de la barrière de la langue du coup je me permet de les traduire pour que tu puisse y répondre (n'hésite pas a me demander si tu veux de l'aide pour répondre )Entre () et avec mon pseudo ce sont mes "notes de traducteur" I love all this work, but I just noticed something...the Warhound is missing a toe. Where did his toe go? J'adore tout votre boulot, mais je viens juste de remarquer un truc ... le Warhound a un orteil en moins. Ou est-il passer ? !!! Wow! Can you share your paint recipe for the burnished metal?? So gorgeous Peux-tu partager ta recette pour le métal vieilli ? Tellement beau (Lasuria: il parle du corps du warlord) Martian Ironearth (...) should be used straight out of the pot, not watered, and slathered on. Martian Ironearth devrait être utiliser directement depuis le pot sans le diluer et appliquer directement. (Lasuria: pour l'avoir utiliser moi-même il faut effectivement mettre une bonne couche et laisser sécher pour que ça craquelle) Stunning work. I do have to ask though, what happened to the original head? Did you make alternatives? Magnifique. J'ai une question néanmoins, qu'est-il arrivé a la tête d'origine (Lasuria: du warlord) ? Avez-vous fait plusieurs têtes ? Do you have any plans with the Adeptus Titanicus titans? I reckon they would be an awesome opportunity for more or even riskier conversions, in a much more affordable "canvas" . Est-ce que vous avez l'intention de peindre des titans de la boite Adeptus Titanicus ? Je pense qu'ils présentent une superbe opportunité pour des conversions plus poussées et/ou plus risquées sur un "canevas" bien plus abordable financièrement Edited August 24, 2018 by Lasuria 2 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5153137 Share on other sites More sharing options...
Lasuria Posted August 25, 2018 Share Posted August 25, 2018 Sorry for the double post but Crevette took me up on my offer to translate for her so below are her answers (in bold and dark orange), I also added Crevette's original answers for those of you who speak French (as I'm not a professional translator, and not immune to mistranslate -especially the painting recipe-). I love all this work, but I just noticed something...the Warhound is missing a toe. Where did his toe go? Crevette: I've bought the Warhound a long time ago and moved out since ... I've lost the toe in doing so. I should rework it as if it was destroyed ... Hidden Content J'ai acheté le warhound il y a très longtemps et j'ai déménager entre temps… J'ai perdu un doigt de pied. Il faudrait que je le travail comme si il avais été détruit... !!! Wow! Can you share your paint recipe for the burnished metal?? So gorgeous Crevette: Here is my usual recipe for rust on the whole army: - RHINOX HIDE base - I tap SKRAG BROWN with a large brush - I tap TROLL SLAYER ORANGE "lightly" - I add a layer of NULN OIL GLOSS For the Warlord body specifically I more or less willingly forgot the NULN OIL - however I added a layer of "YELLOW SAND" from prince august air with an air-brush to give a unique look to the titan - I shadowed with AGRAX EARTHSADE - I highlighted the edges with USHABTI BONE Hidden Content Ma méthode traditionnel pour l'ensemble de l'armée pour la rouille: - base en RHINOX HIDE - je tapote au gros pinceaux en SKRAG BROWN - Je tapote plus "finement" au TROLL SLAYER ORANGE - Je passe une couche de NULN OIL GLOSS Pour le corps du warlord j'ai oublié le NULN OIL plus ou moins volontairement - Par contre j'ai passé une couche de "JAUNE SABLE" prince august air à l'aérographe pour donner un aspect inédit au titan - J'ai ombré avec de l'AGRAX EARTHSHADE - j'ai éclairci les arrêtes à l'USHABTI BONE Martian Ironearth (...) should be used straight out of the pot, not watered, and slathered on. Crevette: Thank you I'll try it on future models (Peltast and Hoplites ) Hidden Content Merci je testerai sur de futurs figurine (pélastre et oplites ;-)) Stunning work. I do have to ask though, what happened to the original head? Did you make alternatives? Crevette: Which one? Joking aside I have the three titan's heads ... The alpha pattern one is not yet converted though I already know what I want to do ... Hidden Content heu? laquelle? blague à part j'ai les 3 têtes de titan… La Alpha patern n'est pas encore convertie bien que j'ai déjà l'idée... Do you have any plans with the Adeptus Titanicus titans? I reckon they would be an awesome opportunity for more or even riskier conversions, in a much more affordable "canvas" . Crevette: It's probable that I buy Adeptus Titanicus when someone brave enough translate it in French, then the goal will be to do an accurate reproduction of my current maniple and later on of the entire Westgam legio titanicus. Hidden Content Il est probable que j'achète Adeptus Titanicus quand des braves traduirons les règle en .fr. puis l'objectif sera dans un premier temps faire une reproduction fidèle du Manuple actuel puis de réalise l'ensemble de la légion titanique de Westgam… y à un peu de boulot… 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5153481 Share on other sites More sharing options...
dchmp Posted August 26, 2018 Share Posted August 26, 2018 One the best jobs I've ever seen! 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5154099 Share on other sites More sharing options...
Brother Lunkhead Posted August 26, 2018 Share Posted August 26, 2018 Beautiful madness ……. such fine work! Thanks for sharing 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5154237 Share on other sites More sharing options...
Crevette Posted August 26, 2018 Author Share Posted August 26, 2018 the works of Week end… not lot of news thank you all 4 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5154270 Share on other sites More sharing options...
ElDuderino Posted August 26, 2018 Share Posted August 26, 2018 It's hard to say anything constructive in this thread, everything is so incredibly beautiful 3 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5154273 Share on other sites More sharing options...
Bjorn Firewalker Posted August 27, 2018 Share Posted August 27, 2018 Beautiful work. 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5154396 Share on other sites More sharing options...
Crevette Posted August 31, 2018 Author Share Posted August 31, 2018 my last pics of Week 16 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5158201 Share on other sites More sharing options...
Pearson73 Posted August 31, 2018 Share Posted August 31, 2018 Absolutely breathtaking. 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5158210 Share on other sites More sharing options...
Bjorn Firewalker Posted September 1, 2018 Share Posted September 1, 2018 Excellent painting and assembly. 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5158474 Share on other sites More sharing options...
Crevette Posted September 1, 2018 Author Share Posted September 1, 2018 Definitive position in my shop window and new project 9 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5158866 Share on other sites More sharing options...
Bjorn Firewalker Posted September 1, 2018 Share Posted September 1, 2018 The Chaos Knight looks promising. Will he serve Chaos Undivided, or exclusively one of them- maybe Malice, considering the colors he bear? 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5158868 Share on other sites More sharing options...
Jackalwolf Posted September 2, 2018 Share Posted September 2, 2018 golly gee this is incredible!! 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5159134 Share on other sites More sharing options...
Crevette Posted November 11, 2018 Author Share Posted November 11, 2018 after a big pause... My news scenery for dark Mechanicus 9 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5189629 Share on other sites More sharing options...
Brother Lunkhead Posted November 11, 2018 Share Posted November 11, 2018 Your scenery piece looks very fine I've been lax in visiting your site..... I hadn't seen the final pics of your finished Warlord..... absolutely awesome 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5189638 Share on other sites More sharing options...
Crevette Posted December 27, 2018 Author Share Posted December 27, 2018 my news war machine enjoy 18 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5223767 Share on other sites More sharing options...
Bjorn Firewalker Posted December 27, 2018 Share Posted December 27, 2018 Excellent work on the assault drill. 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5223912 Share on other sites More sharing options...
sockwithaticket Posted January 1, 2019 Share Posted January 1, 2019 Weathering on the last two pieces is top notch. 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5226297 Share on other sites More sharing options...
Crevette Posted June 1, 2019 Author Share Posted June 1, 2019 Hello i want to post my new pic but i have message error: you are not allowed to use that image extention on this Community? What is this? Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5323787 Share on other sites More sharing options...
Excessus Posted June 1, 2019 Share Posted June 1, 2019 What kind of image is it? 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5323803 Share on other sites More sharing options...
Xin Ceithan Posted June 2, 2019 Share Posted June 2, 2019 Hello i want to post my new pic but i have message error: you are not allowed to use that image extention on this Community? What is this? I ran into the same error message a day or two ago..... I then just set the post up once more and it worked out fine. 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5324373 Share on other sites More sharing options...
Crevette Posted June 2, 2019 Author Share Posted June 2, 2019 My last work on castelan's leg 12 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5324509 Share on other sites More sharing options...
Bjorn Firewalker Posted June 3, 2019 Share Posted June 3, 2019 Impressive work. Is that Knight Castellan crushing an enemy vehicle until its fuel tank erupts and bursts into flame? Or is its leg burning because enemy attacks ignited that limb? 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/13/#findComment-5325302 Share on other sites More sharing options...
