Sgt. Blank Posted January 1, 2020 Share Posted January 1, 2020 (edited) Wowza, the banelord looks impressive so far. Are the wires armatures for the horns? If so, it's going to look awesome once that space is filled in. I think the tough part of working on something that big is getting an appropriate level of detail and weight and from that I can see you're handling both pretty well so far - keep it it, I'm interested to see it come together. Edited January 1, 2020 by Sgt. Blank Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5454075 Share on other sites More sharing options...
Crevette Posted January 1, 2020 Author Share Posted January 1, 2020 Wowza, the banelord looks impressive so far. Are the wires armatures for the horns? If so, it's going to look awesome once that space is filled in. I think the tough part of working on something that big is getting an appropriate level of detail and weight and from that I can see you're handling both pretty well so far - keep it it, I'm interested to see it come together. The work is not easy. I carve a little then I have to wait until it is dry to continue. it is a relatively low yield. this is the first time I work with clay ... it allows to treat larger areas than with green stuff I am impatient to finish and finally start painting. I would use the technique that @KrautScientist kindly entrusted to me ... concerning the red I am still looking for the right formula to get closer to the color of adeptus titanicus dominus Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5454117 Share on other sites More sharing options...
Kolgrim DeathHowl Posted January 1, 2020 Share Posted January 1, 2020 Ohh wow looking even better than before!! Keep up the good work, looking forward to seeing more!! Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5454244 Share on other sites More sharing options...
Crevette Posted January 2, 2020 Author Share Posted January 2, 2020 I didn't really like what I had produced so far for the horns but it is starting to look like it ... this is already the third technique I use: green stuff, milliput and now papier maché on aluminum support Mendi Warrior and Sagentus 2 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5454656 Share on other sites More sharing options...
Mechanist Posted January 2, 2020 Share Posted January 2, 2020 Papier maché can do some nice stuff and it might work out well but to be honest I'd go with greenstuff over the aluminium foil. Might be worth a quick thin layer of 50/50 greenstuff and Milliput onto the foil for the bulk of the coverage but then work the finer details with Greenstuff. The shape really works though and whatever you chose to go with keep the foil support. Great job. Crevette and Lucerne 2 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5454857 Share on other sites More sharing options...
Kolgrim DeathHowl Posted January 2, 2020 Share Posted January 2, 2020 Looks promising now!! Looking forward to seeing more of it done! Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5454861 Share on other sites More sharing options...
Crevette Posted January 3, 2020 Author Share Posted January 3, 2020 I moved a lot yesterday. I worked until 1 am.- I finished making 3 displays that I had planned for the heads of the titans (morning so no photo of the final rendering for the moment).- I also finished the sculpture of the head (I have only 2 teeth left to do). I took over the tips of the horns, I "webbed" the first two horns… picked up and remade the junction between the horns and the skull… We are here- I ironed PVA on the clay so as not to have a porous effect on the paint and that the clay does not drink the paint too quickly.- The display allows you to show the "coat of arms" of the titans, I'm sadly lost ... but I found another piece that will do the trick. And only those who follow the realization of the titans from the beginning will find that it is this piece… which I was repugnant for the Dark Mechanicus but which, for a Banelord this justifies quite! Photos? Okay... Kolgrim DeathHowl, Mendi Warrior, Sagentus and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5455150 Share on other sites More sharing options...
Crevette Posted January 5, 2020 Author Share Posted January 5, 2020 End of Banelord head Trokair, Grotsmasha, Thousand Eyes and 9 others 12 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5456417 Share on other sites More sharing options...
Sgt. Blank Posted January 5, 2020 Share Posted January 5, 2020 Overall, it looks amazing and way beyond anything I'd even attempt. As good as it looks, the texture on the horns looks a bit off to me - maybe it's from looking at the work - in - progress pictures but it does look like paper mache to me rather than horn, particularly next to the excellent sculpting on the face. I like how much it looks like a Bloodletter and to play that up further, I'd suggest either tilling in the wrinkles and smoothing it out completely (maybe with wall repair filler or something else that's easy to smooth out and can be sanded) or more textured like a horn. Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5456444 Share on other sites More sharing options...
Kolgrim DeathHowl Posted January 5, 2020 Share Posted January 5, 2020 Wow it really looks great with some paint on it, and the full shot of the whole thing is pretty menacing looking. Nice work so far! Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5456482 Share on other sites More sharing options...
malika666 Posted January 6, 2020 Share Posted January 6, 2020 Im officially frightened.... Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5456977 Share on other sites More sharing options...
Crevette Posted January 13, 2020 Author Share Posted January 13, 2020 Here it is finished for a few days but here are the last details: I therefore went back to the Porphyrion which makes me a little head to have left it like this: Dr_Ruminahui, Sgt. Blank, DuskRaider and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5460514 Share on other sites More sharing options...
Kolgrim DeathHowl Posted January 13, 2020 Share Posted January 13, 2020 Looks great nice work!! Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5460519 Share on other sites More sharing options...
The_son_of_Dorn Posted January 13, 2020 Share Posted January 13, 2020 Banelord. Because words can hurt too....alot. Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5460525 Share on other sites More sharing options...
Crevette Posted January 26, 2020 Author Share Posted January 26, 2020 Good for the future:The Banelords are equipped with missile launchers on the shoulders. So I recommended the parts that I didn't have.I trimmed the borders to make it more chaotic (as usual) and now leave for @thyrio for the rest of the sculpture I got some coins from eBay from Lord of Skull. It gives the color theme of the beast Here is the Quake cannon tinkered with a Titan Volcano cannon, part printed in 3d, and rest of Lord of Skull Here is where I am at the moment. We are, with a friend, printing in 3d the rest of the pieces of armor that we are missing but basically you see the pieces that we will keep for this Banelord version Xin Ceithan, DuskRaider, Lasuria and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5467854 Share on other sites More sharing options...
Crevette Posted March 26, 2020 Author Share Posted March 26, 2020 end of Porphyrion envoy Dr_Ruminahui, Majkhel, Sagentus and 15 others 18 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5496822 Share on other sites More sharing options...
Mendi Warrior Posted March 26, 2020 Share Posted March 26, 2020 Epoustouflant! Excellent work, I love it! Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5496845 Share on other sites More sharing options...
Elzender Posted March 26, 2020 Share Posted March 26, 2020 As exquisite as ever, Crevette! Looking forward to further updates on the Banelord :D Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5496937 Share on other sites More sharing options...
Thyrio Posted April 8, 2020 Share Posted April 8, 2020 (edited) Hi, guys, i'm back with the chaotised armor from our banelord with Crevette nearly finished I convert too a new time the legs from our first IK with Crevette, i found the legs laked mechanical gears, so i had them with GS and i changed the knee: finished: I work too on a new shell with horns and the shoulders Edited April 8, 2020 by Thyrio Lasuria, Chaplain Raeven, Dr_Ruminahui and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5503816 Share on other sites More sharing options...
Crevette Posted April 29, 2020 Author Share Posted April 29, 2020 here is some picture of the titan's armor first stage second step personally I like it. What do you weigh? Grotsmasha, Xenith, Xin Ceithan and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5513997 Share on other sites More sharing options...
Swarbie8D Posted April 29, 2020 Share Posted April 29, 2020 Wow that is a gorgeous flame pattern. Well done! I’ve been reading this whole thread and everything is incredible, you two have put in so much work! Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5514587 Share on other sites More sharing options...
Crevette Posted May 17, 2020 Author Share Posted May 17, 2020 Failing to have finished the Banelord I finished this:my 3rd and last knight Galloway, Sandalphon, Dr_Ruminahui and 12 others 15 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5522681 Share on other sites More sharing options...
Xin Ceithan Posted May 17, 2020 Share Posted May 17, 2020 We will kindly overlook you failing to finish the Banelord since you shared this pretty knight with us ;) No kidding, that IS an excellent knight. And, personally, I would probably be to afraid to ruin the model to even start something as mad as your Banelord. So take your time doing it. We will be here to wait for it's conclusion. It will surely be worth the wait! Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5522723 Share on other sites More sharing options...
Crevette Posted August 30, 2020 Author Share Posted August 30, 2020 We are going to make a little trip back to the past here because by simple fleme I did not show us the previous productions: Here I am back with some better quality photo. The three weeks of vacation have been prolific! To start two units of the 10 figures: @thyrio's electro-priest called "squid" Then 10 skitarii based on Necromunda minifigure The two units stayed on the corner of my desk for a very long time because I was not very motivated ... The skitarii are boring to paint and not very glorifying ... For the Squid it was the bronze which (intellectually) was painful, then in the final it quickly passed ... Before going on vacation I really wanted to paint horses, so Thyrio prepared 6 riders for me. There were also two Balistarii left lying in a box. I took the opportunity to do a group shot Now the 2 serious subjects: 2 versions of Belisarius Cawl, The first which is the interpretation of Thyrio. No particular topic on this piece other than the delirium on the ultramarine armor plate on the ground. an afternoon of work alone ... to finally be hidden ... lol And finally Balisarius Cawl Apocalypse version ... it's still in Wip because I have not yet found how to finish the "back". Note the presence of corpses in the body of the beast Good to make you happy the holidays we also allowed to pose a little and find some new concept a little fun ... For those who like the imperial artillery and the aractaphrons you will be served ... but I say no more For me the next step is to manage to finish the equivalent of the units that I painted for my boyfriend. Indeed I have almost painted all of the Mechanicus codex entries for @thyrio but I have only finished very few for myself. Well, of course it's not for playing because personal I prefer day with few figurines, so my Chaos Knight have already been operational for 1 year already ... What next? the end of the hoplite, the beginning of the pelasts (or indeed the opposite, I don't remember the names well), of the s ***** o **** as servants ... and SMC with Boobs ... because that I like that! there is also the big one with FW coming but that's top secret for the moment ... Majkhel, ChazSexington, Master Umbra and 9 others 12 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5593908 Share on other sites More sharing options...
Xenophon40k Posted August 30, 2020 Share Posted August 30, 2020 Grim and cool Crevette 1 Back to top Link to comment https://bolterandchainsword.com/topic/325481-dark-mechanicum/page/15/#findComment-5593911 Share on other sites More sharing options...
