In a purchasing or army list context?
Any sisters player probably wants at least two as a transport option for dominions / character pieces. Beyond that you can make do with regular mk2 rhinos as required.
Exorcists can also be glued together in a way that allows them to be used as immolators as required.
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4490636
One for each rhino... I have 13, some say that is too many. I tell my wife that is Heresy....
Okay, I've just brought 3. I also have 3 exorcists and will have 4-6 Rhino. :)
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4490642
I have one per dominion squad, because 4 meltas attract a lots of attention so they need to get to their targets in a can, plus a few for troops if I want to field small units. The trick is to keep the Immo turrets from Exorcists if you have the GW version of the latter, and put them on the Rhinos when needed (as I have rhinos for the bigger troop squads). One of my immolators is a conversion from a Baal Predator, but removing the turret and putting in a homemade piece of armor also does the reverse trick to make it a rhino, so it's quite flexible.
So that makes 3 immolators for dominions + 2 turrets to put on the rhinos if needed for troops, in my case. My dominions always ride immolators. My troops, depends. I like the versatility of "convertible" rhino-immolators.
Edit: spelling
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4490644
I own 2, and that seems to be plenty all the way up to 3k points.  After that, I would consider more but I've never played higher then that :p
Rhino's make up the bulk of my transports (there's usually 1 extra Rhino then there is Immolators on the board), but sometimes I will swap the Rhinos out for Repressors if by some miracle I have points to spare :p
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4490698
I own 2, and that seems to be plenty all the way up to 3k points. After that, I would consider more but I've never played higher then that tongue.png
Rhino's make up the bulk of my transports (there's usually 1 extra Rhino then there is Immolators on the board), but sometimes I will swap the Rhinos out for Repressors if by some miracle I have points to spare tongue.png
Good shout on the rhinos.
Also, I just clicked on the the link to your YouTube Channel, didn't realise that you are Tortle :) :3
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4490827
and I thought i was bad for having 12 repressors
You definitely have me there. I have four scratch built ones, three are painted. End of summer festivities have kind of derailed my ETL painting momentum. Ive been spending what little time I have getting the last two repressors converted. Nearly to the priming stage.
I was looking today and I have some of the MK1 immolator bitz in my box if anyone is interested. Also, I know missing backpacks are an issue for a lot of folks. I have been taking a serious look at what I need of what I have of Sisters models. I will be looking to get rid of packs, dialogus, sacred banner and simulacra models, as well as the usual suspects in the near future.
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4491448
Converted/authentic/full spaced armour?
I've had a half-finished mistress of the choir for about half a decade now with spaced armour... undecided about whether I want to rip the armour off to make one last repressor in the event forgeworld ever put it back up for sale.
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4491894
I only have eight of the Mk I Immolators, most from the 2nd Ed. days. I converted four of the turrets when other gun options became available, two heavy bolters and two multi meltas. I can also use them as either Rhinos, (eight turret hatches with storm bolters on top,) or Exorcists, ( three missile rack turrets made from Tamiya Foot Stuka model kits, this was before the official Exorcist kit came out:) )
I love the Repressor and have six I converted from old Rhinos plus two official Forge World models, ( which look much cooler than my conversions.) My fluff is that the FW models are the Cadillacs that the commanders get to run around in while the converted ones are the Dodges that the regular troops get.msn-wink.gif
Incidentally, you will find that, for some strange reason, your opponents will have an irrational prejudice against Repressors. Something about AV 13 and five people shooting melta weapons or heavy flamethrowers out of them. Doesn't make sense to me, but who can fathom the thoughts of heretics?
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4498161
I have one official one and two made from a standard Rhino chassis with the Razorback backplate mount along with the spare Immolator parts from the Exorcists I have. Ideally, I'd love more, but that would mean more Exorcists, and whilst I love the two I have, they are the absolute censored.gif to assemble.
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4498587
haha. This is exactly the set of models I have. (1 official immo, 2 converted immo, 2 exorcists)
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4498592
I thought about converting one from the Exorcist spares too, but will see if I'll actually do it at some point. And I actually did order one more Immolator via the FLGS in the spring of last year, but they couldn't order it in at that point. I ended up ordering the Exorcist from GW directly a few months later, but didn't get the Immolator.. can't remember if it was out of stock at that point or if I was just broke ;)
And yeah, as for assembling the Exorcist... I haven't been brave enough to try it yet biggrin.png
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4498643
Depends on how much you want the tubes to sit flush with the vehicle. The rest of it goes together fairly easily barring slightly warped side plates but the base for the tubes is a terrible fit.
I gave up and just hid the gap behind a couple of laud hailers from the bastion/defense wall set.
Exorcists
https://bolterandchainsword.com/topic/325511-immolators/#findComment-4498832
