Darkn3ssF4lls Posted September 12, 2016 Share Posted September 12, 2016 has anyone found good deals on terrain on ebay etc? the stuff from gw is quite expensive, i guess i could make a jungle with aquarium pieces with rocks etc. im looking to do city scape though Link to comment https://bolterandchainsword.com/topic/325732-terrain/ Share on other sites More sharing options...
Canadian_F_H Posted September 12, 2016 Share Posted September 12, 2016 I used to build my own terrain... all the white dwarf mags from a decade ago had a full article on building all kinds of terrain for a full table followed by a batrep fought over that table... There are some websites out there full of tutorials. I'm sure someone here remembers what they are called... As for alien jungle worlds I too was eyeballing some aquarium faux fauna. Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4498674 Share on other sites More sharing options...
Isolia Posted September 12, 2016 Share Posted September 12, 2016 I also try to build, "the terrain tutor" has some nice videos on YouTube that I like to watch to learn some tricks or basic advice :) I never saw good deals on eBay on stuff that I wanted, because it's usually somehting oop and thus is up for speculation , so I started to try and build my own Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4498829 Share on other sites More sharing options...
DistroyA Posted September 12, 2016 Share Posted September 12, 2016 Terrain Tutor on YouTube is a good start for building your own terrain, as is Miniwargaming's channel. Plus there's a user on here (I forget the name) who posted a link to a page on his blog to print out terrain templates. Definitely worth checking out. :) Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4498865 Share on other sites More sharing options...
old git Posted September 12, 2016 Share Posted September 12, 2016 There is also lots of lasercut MDF terrain out there which is far more reasonable in price. Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4498874 Share on other sites More sharing options...
Major_Gilbear Posted September 12, 2016 Share Posted September 12, 2016 Generally, I would normally suggest making your own - much more economical for a similar level of work. Necromundicon/Ironhands has some great tutorials for making your own cheap but good-looking terrain here. Rob Hawkins is a professional terrain maker (for GW, Privateer Press, CMON, and many others), and he often shares his efforts and tutorials on his blog here. To paint terrain, I would suggest using internal vinyl paints - you can get colour-matched tester pots for just a few dollars, and they are much better and cheaper for painting terrain with. Plus, when you finish the tins, you can make even more scenery out of them! ;) Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4498898 Share on other sites More sharing options...
Space Truckin Posted September 12, 2016 Share Posted September 12, 2016 Rob Hawkins is a professional terrain maker (for GW, Privateer Press, CMON, and many others), and he often shares his efforts and tutorials on his blog here. :tu: thanks for this. I'll be checking it out on my lunch break. Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4498920 Share on other sites More sharing options...
Guiltysparc Posted September 12, 2016 Share Posted September 12, 2016 I commissioned a set of terrain from green leaf terrain, it is absolutely fantastic and working with Green Leaf was great. Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4499014 Share on other sites More sharing options...
Darkn3ssF4lls Posted September 12, 2016 Author Share Posted September 12, 2016 Awesome everyone thank you :) Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4499026 Share on other sites More sharing options...
Canadian_F_H Posted September 12, 2016 Share Posted September 12, 2016 I plan on building a board from a core of plywood. Starting with 4, 2'x2' panels, and later boost by 4 more. Lay them out like a topographical map. Basically a full 4x4 foot area then work my way up and create the hills and valleys. Make it such that anything that hits a 2x2 sections edge will line up with every other 2x2 edge, so I can create a valley in the middle, or rotate all boards 180deg for a hill in the middle, or 90deg for a hill on either side of the table etc etc. Fill in gaps with some sort of filler material. Sand, textremely and paint... then build small ruins and wooded thickets that fit in flat areas in the board that can be swapped around as needed. Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4499112 Share on other sites More sharing options...
Grotsmasha Posted September 15, 2016 Share Posted September 15, 2016 Give Miniature Scenery a look. Cheers, Jonp Link to comment https://bolterandchainsword.com/topic/325732-terrain/#findComment-4502766 Share on other sites More sharing options...
