deathwatch veterans conversion to acolytes
BolterTama
Are you thinking of using them as acolytes in power armour?
With inquisition colour can be whatever you want. I would avoid deathwatch colours though so that it's clear that they are not marines. You should try to somehow tone them so they're clearly regular humans in power armour not space marines. Not sure how to do that, maybe use regular human (Cadian or Scion) heads, leave off the shoulder pads, use something smaller (3rd party bitz) for the backpacks.
As, above. To avoid confusion, changing the silhouette away from the classic SM is the best path. Different head, shoulder pads and power plant will definitely achieve this. Either Cadian or Scion heads would work, you could source 3rd party power packs or trim down and rearrange SM packs.
Cheers,
Jono
