JB weld
Canadian_F_H
JB Weld is my go to 2-part epoxy. Never had any problems using it on miniatures. It works really well on metal minis. Good to go on plastic and resin. It's the only thing that i have found that will hold the original RT landspeeder together.
The only down side is having to hold the parts in position while it cures. Once it cures you're not getting the pieces apart.
https://bolterandchainsword.com/topic/325822-jb-weld/#findComment-4502470
I actually used it to fill the hole in the washers I used for the new base for my terminator librarian. I had trimmed the perimeter of his old 25mm slot base, and stuck the tab into the hole in the washers and the top of the old base sat nicely on the top lip of the hole... that was glued on with super glue. I then came back later and filled in the pocket with the JB weld.
https://bolterandchainsword.com/topic/325822-jb-weld/#findComment-4504612
Has anyone tried it on resin? I'm about to start building my Spartan and I'm feeling like I want something a little more heavy duty than superglue.
I've used it successfully on my Warlord titan. To be honest I'm not sure there's much else I'd trust on a large model
https://bolterandchainsword.com/topic/325822-jb-weld/#findComment-4506562
