Thunderbolts
I was afraid of that. They're recasts, I can tell by the type of resin used, it's definitely not FW, but it's still substantial.
So I'll need to get some thin plywood and dowel rods, and some drill bits and make some flyer stands for them.
https://bolterandchainsword.com/topic/325824-thunderbolts/#findComment-4501300
I just superglued a valkyrie flyer 'socket' to the underside of mine, though you'd need to scour the bitz sites for them.
I thought about that. But that doesn't seem to be a common piece.
is it a big problem to glue some sprue peices to form a frame for the cross?
I had that thought too, but I didn't know if it would be stable or not, considering the trapezoidal cross section of the sprues.
You can also go down the route of using a dremmel or similar to cut out a recess for the + of the flying stand. This is what I ended up doing for a Barracuda and TigerShark and as long as you are careful it works...
Problem with that is, there are landing gear bays in the way, which would make it unstable.
I did find a valkyrie stand and socket on a bitz site for under $10, so that might be the direction I go, considering I'd like to have stands to go with the thunderbolts, rather than use stands from other flyers (so I can field all of my flyers at once, mua-ha-ha-haa...).
https://bolterandchainsword.com/topic/325824-thunderbolts/#findComment-4501960
The stand isn't the problem. It's how to attach the model to the stand that's the problem. The kits I received did not include a way to mount them on a stand, which means I have to come up with my own way.
The Bitz sites are looking like the best option.
https://bolterandchainsword.com/topic/325824-thunderbolts/#findComment-4501983
Well, Elmo of the Commissariat has come through. I think I know how I'm going to do this. After I get the little thingy, I'll probably sculpt a second from green stuff using the thingus as a template.
I might still get the valkyrie stand parts as an added measure for insurance though. If nothing else they'll find use if I ever get more of these things...
https://bolterandchainsword.com/topic/325824-thunderbolts/#findComment-4503161
