Washing FW resin bits
Well, I just finished washing my new FW bits (chainaxes, BPs, Shoulder pads, Kheres AssCan) as I do all my models with some dishwashing soap and a toothbrush but after I dried them off they were still super slick. Is that a sign the mold release agent wasn't fully cleaned off?
https://bolterandchainsword.com/topic/326168-washing-fw-resin-bits/
Sometimes you'll get a batch of faulty resin. You'll know it's bad if you've cleaned the item more than once and it's still exuding slickness. If that is the case, contact Forge World by phone or email and they'll fix you up. This phenomenon has a name but I can't think of it at the moment.
Sweat.
Yeah - sometimes the resin isn't mixed correctly, and you get items that seem to release oils despite being washed a few times. If it's really bad you should call ForgeWorld, but if it's slightly tacky then you can probably get away with doing a coat of Purity Seal before the Undercoat. In general I always use Purity Seal, and even if the resin is still shiny / sticky it's never resulted in paint flaking off.
  • 2 weeks later...
A bit late to the party on this one sorry but wanted to double check that what I'm about to suggest actually works. I've now used it on my Mastodon which still had several areas of "slickness" after my usual de-greasing wash, and it's worked fantastically.
It's a paste called Key and Clean, Paint Preparation for Modellers from Zero Paints.
http://www.hiroboy.com/Key_and_Clean_Paint_Preparation_and_Cleaning_Solution_75g--product--2311.html
It comes with 2 finishing pads which you can use on the large, more stubborn areas but mostly I used an old toothbrush or nailbrush to clean smaller parts.
OP, I've found that a coat of matte varnish seems to work on even the most stubborn release agent. Now I coat all my resin with it before priming. Alternatively, depending on where and what the piece is, gently sand/file/scrape off the top layer 'til you hit resin.
Ive never cleaned my resin and everything is holding paint fine.
I dont understand...
Then you're either super lucky or haven't handled your models all that much, this is a pretty well documented phenomenom.
  • 3 weeks later...
I had similar problem with FW resin. It got solved by leaving the bits in warm water with dishwashing detergents dissolved in it, leave it for ca 20-30 min and the release agents will soften up and come off much easier when brushing with a soft toothbrush and dishwashing detergent
