Commissar Ibram Gaunt Posted September 25, 2016 Share Posted September 25, 2016 I am moving oj to painting up some tanks and knights in the coming weeks and was wanting to use some oil washes on them and techniques from FW masterclass books. As i do not own an airbrush does anyone have suggestions for what type of varnish I could use pre and post oil wash and one that could give a nice finish once completed. Would prefer something with no odour. Does anyone have any recommendations? Link to comment https://bolterandchainsword.com/topic/326245-aresol-or-brush-on-varnish-for-oil-paints/ Share on other sites More sharing options...
Udo Posted September 28, 2016 Share Posted September 28, 2016 The idea is to use a water based varnish to seal the oil paints in. Obviously aerosol varnishes are not water based. I'd be concerned with a brush on varnish disturbing the oil wash, destroying your good work. Link to comment https://bolterandchainsword.com/topic/326245-aresol-or-brush-on-varnish-for-oil-paints/#findComment-4514603 Share on other sites More sharing options...
Commissar Ibram Gaunt Posted September 28, 2016 Author Share Posted September 28, 2016 The idea is to use a water based varnish to seal the oil paints in. Obviously aerosol varnishes are not water based. I'd be concerned with a brush on varnish disturbing the oil wash, destroying your good work. So basically without an airbrush there are no options? Link to comment https://bolterandchainsword.com/topic/326245-aresol-or-brush-on-varnish-for-oil-paints/#findComment-4514697 Share on other sites More sharing options...
Major_Gilbear Posted September 29, 2016 Share Posted September 29, 2016 You can get brush-on water-based PU varnishes instead. As long as the oil paints/whatever are fully dry and don't rub off too easily, there is no reason you cannot use these to seal the model with. Just apply a thin layer carefully, and try not to "work" it too hard so that you don't disturb any layers underneath. You cannot use these brush-on varnishes over powdered pigments easily however, but other fixatives like strong hairspray an old modellers' favourite that you could consider for helping to seal these powders instead. Link to comment https://bolterandchainsword.com/topic/326245-aresol-or-brush-on-varnish-for-oil-paints/#findComment-4515158 Share on other sites More sharing options...
