Need help with Betrayal at Calth and White Scars
Warax
Hi guys, i was wonderig what are your thoughs with starting a White Scars army using the BaC. After looking at the rule
for the White Scars i'm not sure the BaC would be usefull for a new army! I was really torn between Imperial Fist, Salamander and White Scars, but after reading fluff, settle on the Scars until i looked at their rule and Rites of War... FW jetbike and Bike are really expensive, so... I'm not sure anymore what fo you guys think?
Tacs in rhinos suit the scars perfectly as well! You aren't by any means bound by their rites of war anyway. And if you do want bikes simply use the plastic GW ones and just swap around some parts to taste!
White Scars benefit from being on the move, which Tacticals can be, just not by the same factor as mounted troopers. White Scars Tactical Support can be quite daunting also, especially rapid firing plasmas on the move!
