Converting The Ultramarine trio
Has anybody taken a krak at converting these guys yet?
https://www.games-workshop.com/en-US/Space-Marines-Starter-Paint-Set-2016
I am curious about any conversions, especially to other chapters.
Can't be that hard.
Just take a small file and wittle those markings off, then decal it up like normal marines.
One tactical arrow, and one ultramarines symbol... Not hard to scrape off, and the arms can be swapped out for regular arms instead anyway.
I suspect that for the teeny-tiny amount of paint you get in the set, essentially paying $11 for a snap-fit marine is considered to be poor value for money compared to a "full" set of ten marines that costs $40 (or even a set of three snap-fit Space marines for $10). I'd suggest that's the real reason you don't see many of them around, and not because they are tricky to convert.
I remember reading someone claiming that these models are slightly larger than regular marines and are step towards more true-scale(-like) proportions. I don't want to spread disinformation, though. It's just a hazy memory. Maybe someone can confirm or deny this?
They are a tad taller thanks to the more upright poses, but the actual body parts appear to be the same size as far as I can tell.
Much the same as the new Deathwatch models I believe; stood up straighter rather than actually larger scale.
Actually their torsos do seem to be a bit bulkier and taller as seen in this post.
Hidden Content
http://i.imgur.com/ULoTtp0l.jpg
I really enjoyed the kit not because of the paints (although it got me into using Agrellan Earth on my Ultramarines ever since), but because of the new awesome poses. I might take a swing at another box and converting them.
They are actually pretty decent snap fits.. I would buy them if I came across them for cheap.  GW should make them available for purchase seperately as a cheap tactical squad.  Sometimes I really grow weary of having to put together tactical marines.
Well that's a whole other ball of wax. I've pretty much always wished they would make bulk infantry boxes. Something cheaper with less bits... like 10x imperial guardsmen with only lasguns for $20, and 5x bolter marines for $15. But still multipart. And then specialists and heavy weapons. Broken down. Ie a 5 man dev box with only 4 lascannons for example. I swear right now there are more bits left over than used in that kit without buying a Tac box to use the left over heavy weapons which yields still a ton of bolter bits etc...
But I digress. My bits box doth over flow...
