Black Cohort Posted October 23, 2016 Share Posted October 23, 2016 How would you equip a 5 terminator squad with melee and heavy weapons if you are going volkite for ranged weapons? Currently I am thinking a plasma blaster, swords, mauls or lightning claws for most of the terminators with 1 chainfist. Any advice would be appreciated. Link to comment https://bolterandchainsword.com/topic/327151-volkite-terminator-squad/ Share on other sites More sharing options...
DuskRaider Posted October 23, 2016 Share Posted October 23, 2016 I would go either Heavy Flamers for the template or Reaper Autocannon for the range. As far as melee weapons... Power Fists, Chain Fist and a Power Maul or two. Link to comment https://bolterandchainsword.com/topic/327151-volkite-terminator-squad/#findComment-4541488 Share on other sites More sharing options...
Slips Posted October 23, 2016 Share Posted October 23, 2016 Due to the 15" Range of the Chargers, I'd go with the Plasma Blaster personally. 2 Plasma Shots at 18 or lower gives the squad a bit more punch. If youre a Salamander or Death Guard, the heavy flamer would be a good go due to +1S or Shred (or both in ZM). The Reaper is only really good on a footslogging squad. For Melee Weapons, it depends on the job. In general, Fists with 1 in 3 Chainfists will be the best bet. Otherwise, 2 Single-Claws, 2 Fists and 1 Chainfist gives you a bit more versatility if theyre likely to be fighting 3+ Saves more so than other terminators. If you can't afford fists or claws, axes and swords are the next best thing respectively. Mauls I'd only ever use if you're 100% going up against 4+ saves or weaker / want to ID T3 models on the cheap. Link to comment https://bolterandchainsword.com/topic/327151-volkite-terminator-squad/#findComment-4541555 Share on other sites More sharing options...
