Kastor Krieg Posted December 9, 2016 Share Posted December 9, 2016 Sigh, probably should've just gotten the yellow spray after all. It would've likely been "close enough" to the shade of yellow I want (while these Averland and Golden yellows appear too brownish when airbrushed anyway). As compared to this darned airbrush being more or less clogged when used with anything thicker than water. Took me well over half an hour just to paint the front panel, barrel, mantle and one side extra plate of a Vindicator with the airbrush. With a spray that would've been all of a minute.Dilute 2:1 with Vallejo Flow Improver, Brother. I airbrush Averland and all other Citadel range (Base or Layer) through a 0,2mm nozzle. No issues. Way better, way more control and no toxic spray. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4588165 Share on other sites More sharing options...
tvih Posted December 10, 2016 Share Posted December 10, 2016 I bought the Averland Air version specifically for this purpose, but even it clogs the airbrush rather quick. I found a way to clean it a bit better though, so I managed to basecoat the entire Vindicator now. Today gotta fix a few spots yet, and then try the Golden Yellow layer on the Averland and hope it looks something like it does on Lysander... Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4588832 Share on other sites More sharing options...
Kastor Krieg Posted December 10, 2016 Share Posted December 10, 2016 You can also try Casandora Yellow after the Golden / Yriel highlight.The Air paints, whether from GW or Vallejo, still require dilution. Less, and have more pigment in a more diluted medium, but still. Honestly, Brother, buy the Flow Improver from Vallejo. Not Airbrush Thinner. Flow Improver. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4588912 Share on other sites More sharing options...
tvih Posted December 10, 2016 Share Posted December 10, 2016 Yeah I've been using the Vallejo Thinner Medium now (including on the Averland Air)... I've spent way too much of it already :P Looks like the FLGS doesn't have Flow Improver in stock either. 2 week wait time according to their website The Vindicator just got its Golden Yellow coat, will probably still need some touchups. Gonna examine closer once it dries fully. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4588923 Share on other sites More sharing options...
tvih Posted December 10, 2016 Share Posted December 10, 2016 After a second full pass of Golden Yellow I think it's now the way I want it. But as mentioned before it's getting pricey compared to spray - I think I've used about 2/3 of the GY pot just for this one Vindicator, and I haven't even done the siege shield. I guess I gotta spare the rest for that purpose in case Yriel Yellow ends up notably different in shade (anyone got experience with a comparison of the two?). I also think it looks pretty good like this without a need for any highlighting. Â I wonder what other vehicles I might do in IF colors rather than CF. Maybe one of the Land Raiders so there'd be one CF and one IF. Too bad I already painted both of the dreads as CF :P Â PS. Sorry for kinda hijacking the topic. For clarification and a reply of sorts to the OP is it seems my scheme for vehicles is gray primer (is my case the brand Maston, but unlikely to be available outside of Finland - shame, the new cans I got seem awesome), followed by Averland Sunset, and finished with Golden/Yriel Yellow. I can put up a picture in a little while after it dries again, if anyone's interested. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4589015 Share on other sites More sharing options...
Deathbyppt Posted December 13, 2016 Share Posted December 13, 2016 use cheap-o white primer from Walmart and then spray Vallejo Golden Yellow from an airbrush, shade with Burnt Umber (again from Vallejo) get results. http://imgur.com/a/pAFSQ Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4591710 Share on other sites More sharing options...
tvih Posted December 14, 2016 Share Posted December 14, 2016 The white might indeed remove the need for Averland as an inbetween... but frankly - and sadly - so far none of the white sprays I've tried have been usable, instead being utterly terrible :( Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4593404 Share on other sites More sharing options...
Antarius Posted December 18, 2016 Share Posted December 18, 2016 Â Yeah, I'm guessing the new Averland Sunset spray should do the job. I too have had some trouble with Army Painter sprays, but GW's sprays tend to be much easier to work with plus they're a lot better for doing a relatively thin undercoat. Just PRIME the mini before using that spray. It's just paint. Â The primer/paint distinction might be real but it's really not a problem in any way, shape or form IME. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4596204 Share on other sites More sharing options...
Kastor Krieg Posted December 19, 2016 Share Posted December 19, 2016   Yeah, I'm guessing the new Averland Sunset spray should do the job. I too have had some trouble with Army Painter sprays, but GW's sprays tend to be much easier to work with plus they're a lot better for doing a relatively thin undercoat. Just PRIME the mini before using that spray. It's just paint.  The primer/paint distinction might be real but it's really not a problem in any way, shape or form IME.  It's like saying "my paint won't adhere to the mini and will flake off at any provocation, but it's really not a problem in any way, shape or form IME". The primers are there to specifically deal with a real problem, a situation that requires a PRIMER not paint. Paint goes on primer. Primer goes on model. If there was no need for primer, you can just as well brush paint straight on plastic / resin / metal, to the same effect.  Do what you will, your funeral.  I reserve my right to an "I told you so" further down the road. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4596743 Share on other sites More sharing options...
tvih Posted December 19, 2016 Share Posted December 19, 2016 Like I said before - I've only had flaking problems with metal. Now, mind you, I wouldn't brush on normal paints on even a plastic/resin model, but on those two I've found that pretty much a spray is a spray in terms of adherence, primer or otherwise. On metal models on the other hand even most primers don't work that great. Even if there's no flaking, the paint rubs off extremely easily while working on the model prior to varnishing it. Â 90% or more of my Templars are undercoated/"primed" with non-primer black, and there's definitely no plastic/resin showing up from underneath on any of them even after four years of hauling them around loose in unpadded boxes. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4597079 Share on other sites More sharing options...
Antarius Posted December 20, 2016 Share Posted December 20, 2016 (edited) It's like saying "my paint won't adhere to the mini and will flake off at any provocation, but it's really not a problem in any way, shape or form IME". The primers are there to specifically deal with a real problem, a situation that requires a PRIMER not paint. Paint goes on primer. Primer goes on model. If there was no need for primer, you can just as well brush paint straight on plastic / resin / metal, to the same effect.  Do what you will, your funeral.  I reserve my right to an "I told you so" further down the road.   No. It's like saying "IME my paint adheres just fine and doesn't flake off at all, whether I use a primer or a paint spray" - because that's my experience. I'm totally aware of the whole primer/paint thing and how the different things are supposed to work. It's just that I don't really see any difference in practice between the models where I've used primer and the models where I've used regular spray paint (and, like Tvih, I don't experience any problems even with considerable wear and tear - and I don't even tend to varnish my models).  So yeah. What I will say is that even if the spray cans are just regular paints, they seem to adhere to the models a lot better than regular paint sprayed on with an airbrush (or applied with a brush). When I want to give a black/white/grey basecoat with my airbrush I always use primer, because, like you said that's how it works.  Personally, I suspect that the sprays aren't just regular paint and/or that something happens when you spray from a can to make the paint adhere to the models - and that's probably where our seeming disagreement lies; the sprays just don't seem all that "regular", despite not officially being primer paint. Edited December 20, 2016 by Antarius Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4597728 Share on other sites More sharing options...
Kastor Krieg Posted December 25, 2016 Share Posted December 25, 2016 The aerosol, the "carrier" fluid for the paint in a spray can is a bit corrosive. Which means it will "bite" into the model a tad, hence that feels like better than just paint. But it won't hold there and doesn't envelop the model when drying like an acrylic-polyurethane primer does, goes on nowhere close to as smooth as the old Chaos Black Primer used to, not to even mention airbrushed VSP. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4602729 Share on other sites More sharing options...
cephalopod Posted January 4, 2017 Share Posted January 4, 2017 Try yellow ink mixed with 2% black ink and 50% water. You can also make use of an ink pallet mixing multiple hues and colors. Alot of the color is going to pop once you add the ink. It will help you identify shading points on your models. Don't be afraid to dump a model in simple green. Avoid brown rust colored ink. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4611244 Share on other sites More sharing options...
corvus_rex Posted January 17, 2017 Share Posted January 17, 2017 So I'm considering going with a black base coat, and then a spray coat of Averland Sunset Spray. Does anyone have any advise on where I should go from there? Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4626164 Share on other sites More sharing options...
Sete Posted January 19, 2017 Share Posted January 19, 2017 I am thinking on doing a small Kill Team and I'm gonna go with Imperial primer and then yellow on top. A dark yellow hopefully. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4628111 Share on other sites More sharing options...
ZONKEY Posted February 7, 2017 Share Posted February 7, 2017 Hi,  I am in a similar situation about to start painting some imperial fist and I just want to know what the best idea is, I am just using spray cans and citadel paints if that helps  So my plans is as follows:  1 Prime model with white spray corax white  2 base model with averland sunset base  3 layer with yriel yellow  4 highlight the yellow with screaming skull  Any advice is greatly appreciated :)  - Brother Zonkey Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4648710 Share on other sites More sharing options...
Sete Posted February 7, 2017 Share Posted February 7, 2017 I prime my minis with Imperial primer but I never painted yellow on top of it. How does it fare? Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4648812 Share on other sites More sharing options...
Stoic Raptor Posted February 9, 2017 Share Posted February 9, 2017 1 Prime model with white spray corax white  2 base model with averland sunset base  Why not just spray it with Averland Sunset spray? It replaces those two steps, and saves time and expense. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4651118 Share on other sites More sharing options...
ZONKEY Posted February 9, 2017 Share Posted February 9, 2017 Is wasn't aware averland sunset spray is its own primer Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4651275 Share on other sites More sharing options...
tvih Posted February 9, 2017 Share Posted February 9, 2017 (edited) Averland spray and Corax spray are both the same "grade" of paint, that is, for "basecoating". So one works much like the other as the first layer. Edited February 9, 2017 by tvih Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4651591 Share on other sites More sharing options...
Dickie Skyhammer Posted March 8, 2017 Share Posted March 8, 2017 Put the aerosol can in a bowl of warm water for 10 mins prior to spraying. Ensures the paint is nice and thin. Also go for 2 thin coats rather than 1 hit. Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4677741 Share on other sites More sharing options...
Archaone Posted April 4, 2017 Share Posted April 4, 2017 I've just started IF and i tried to prime with Valejo grey primer , but saldy it was "grainy" (i'm not sure about this one)... Do i need to water it down a bit more ? Or it was about my airbrush ? I was wondering if GW white and averland sunset would do the trick before highlighting with an airbrush Link to comment https://bolterandchainsword.com/topic/327193-spray-base-for-painting-yellow/page/2/#findComment-4703288 Share on other sites More sharing options...
