Brad's Vignettes :)
BT Scout Sniper
Badaab War - Raptors Predatory Cavalry Commander Eric.
Tried to keep the correct colours ( Think I researched correctly)
Let me know what you think?
http://i1243.photobucket.com/albums/gg554/brad_smith16/IMG_20161106_132017_zpsrb8nmuug.jpg
http://i1243.photobucket.com/albums/gg554/brad_smith16/IMG_20161106_131944_zpsbhuzywod.jpg
https://bolterandchainsword.com/topic/327716-brads-vignettes/
Horus Heresy Flesh Tearer :) (yesss I know they were not their then but still cool )
http://i1243.photobucket.com/albums/gg554/brad_smith16/IMG_20160910_090029_zpse8vtlg1v.jpg
http://i1243.photobucket.com/albums/gg554/brad_smith16/IMG_20160910_090259_zpsjz4srwsn.jpg
http://i1243.photobucket.com/albums/gg554/brad_smith16/IMG_20160910_090115_zpsodfyr7oq.jpg
  • 2 weeks later...
Very cool posings and weathering, well done!
I'd like to see a bit more of the old black lining in there so the armour looks like it has segments and can move and bend, they look a teenie bit rigid.
Keep up the awesome work regardless of my musings :tu:
Thanks a heap fellas! :) So my next project I have which im still waiting for parts is a Minotaur Chapter Sergeant that is about to be tainted by the Chaos. It is rumoured that the Chapter was last sighted entering the eye of Terror but is not actually confirmed as they have not been seen since.
So he wont have Chaos Markings but will be standing on a Chaos Base, maybe kneeling to the false Emperor :P
Hi mate, either Airbrush or Wet Pallet the following:
1.Prime white or Grey
2.Apply 2 thin coats of Vallejo Model Colour-Amaranth Red.
3.Apply a Light Dry Brush of Citadel Kindle Flame over the highest points.
4.Once that is done you will want to apply a thick amount of Vallejo Pigment- Dark Red Ocre over the recesses of the base, rubbing it in with the brush. Make sure you leave the highest points the the Dry Brush colour though!
5. Seal base with Matt Spray if desired. If your a Gamer that will not only bind the pigment in position, but will reduce the pigment coming off when you take the model in and out of the case.
Other method you could do, is mix some pigment separate and add water which will essentially turn it into a stain. If you have a look at my Black Templar BIG BUST I have done it on the rear of the pack (Rusty Areas).
[/url]
http://i1243.photobucket.com/albums/gg554/brad_smith16/20161112_140038_zps9fmkzwqj.jpg
http://i1243.photobucket.com/albums/gg554/brad_smith16/20161112_135825_zpsywm15ke0.jpg
http://i1243.photobucket.com/albums/gg554/brad_smith16/20161112_135806_zpsmuyuvajy.jpg
See what I mean. And that can be done with any Pigment (Pastels or model branded Pigments)
